I have two name servers running as a VM in Cloudmin. What do I need to include in the zone named configuration files so that it sees the DNS information from Virtualmin? Right now I am duplicating everything on the name servers. I am sure there is a way to point to Virtualmin VM for it to see the DNS settings.
Your 2 name server VM’s (with just webmin) should be setup as slaves. The vm actually with virtualmin installed is the dns host and will update slaves automatically once setup.
Thanks again for the help. I was able to setup both nameservers as slaves and Virtualmin server as the master. However, I do have one last question…
How would this be configured if I add an additional Virtualmin server? I assume that the domains on both servers need to be updated together. Would I just setup each Virtualmin server as masters? Or, would that overwrite the other?
