Hi to all, yesterday I reinstalled a server in order to change the domain name and host name.
Everything worked fine imported backups and the server was up.
Centos 7 64 bit.
After a hard reset mariadb mysql is not starting any more:
journalctl -xe results ns1.olddomain.tld and ns2.olddomain.tld in all the errors list in terminal.
Googled about query cache flush but since the database server is down I can not use the mysql commands.
in fact this one was the second hard reboot, so it happened after adding the secondary DNS resolver
It seems like you’ve decided on a solution before understanding the problem.
You’ll need to look in the mysql or mariadb log (in /var/log/mariadb, probably) for clues about why it’s failing to start. journalctl -u mariadb or systemctl status mariadb may have more info.
journalctl -xe shows everything on the tail of the journal, which may be wholly unrelated to your problem. (I don’t know what systemctl recommends it when a service fails, since it’s easy to end up seeing nothing related to your problem there). -u tells it which unit to show you log entries for, and is more useful for troubleshooting (though there is a bug in some versions that cause it to miss recent entries, I dunno if CentOS 7 is impacted by that).
Thank you. I reinstalled it again cleared memory cache before virtualmin installation, but this time when I imported the backups from my backups server in Features and Settings selected -> Only those selected below … vy selecting all -> unchecked Records in DNS domain, except SOA and everything looks fine now.
EDIT: again the same problem so strange.
so 5 minutes ago I just added scondary dns in kimsufi.com panel looks like resolver IP is cached its possible?
