| SYSTEM INFORMATION | |
| OS type and version | AlmaLinux 10.1 (Heliotrope Lion) |
| Webmin version | 2.641 |
| Virtualmin version | 8.1.0.gpl-1 |
| Webserver version | Nginx 1.26.3 |
| Related packages | MariaDB 10.11.15 (mysql Ver 15.1) |
When I enable Jailkit for a specific virtual server and then reboot the main server, any WordPress site installed on that virtual server loses its database connection, throwing the standard “Error establishing a database connection”.
Key Observations
- The Error: WordPress is configured to connect to
localhost. After a reboot, this fails. - The Workaround 1: If I change the WordPress configuration (
wp-config.php) fromlocalhostto127.0.0.1, the connection works perfectly even after a reboot. - The Workaround 2: If I keep
localhost, go to Virtualmin, disable Jailkit for that domain, and then reenable it, thelocalhostconnection starts working again immediately (until the next server reboot).
