/etc/apache2/ports.conf
Make sure that the file contents is as follows:
# If you just change the port or add more ports here, you will likely also
# have to change the VirtualHost statement in
# /etc/apache2/sites-enabled/000-default.conf
Listen 80
<IfModule ssl_module>
Listen 443
</IfModule>
<IfModule mod_gnutls.c>
Listen 443
</IfModule>
New replies are closed on that post. Therefore, I thought of creating this post hoping it will help others. I did not copy the original contents of the file. All I have now is what I posted.
SSL issues after I transfer a server from another VPS.
No solution to this as yet.
AH00526: Syntax error on line 74 of /etc/apache2/sites-enabled/example.com.conf:
SSLCACertificateFile: file ‘/etc/ssl/virtualmin/169133753040921/ssl.ca’ does not exist or is empty
Action ‘configtest’ failed.
The Apache error log may have more information.
When I run ‘configtest’ in the terminal, it shows syntax OK.
Both Apache and Dovecot stop working.
After a transfer of an older PHP site with Php7.4., Apache and MariaDB both stop working. I am working on trying to find what exactly is happening. Will post an update on this after I transfer another PHP server.
This happens after every transfer -
Warning!
The Apache configuration on your system has errors! This will prevent any new domains from being fully added by Virtualmin until the errors are fixed.
AH00526: Syntax error on line 89 of /etc/apache2/sites-enabled/example.com.conf:
SSLCACertificateFile: file '/etc/ssl/virtualmin/169140052264536/ssl.ca' does not exist or is empty
Action 'configtest' failed.
A question here:
System Settings → Virtualmin Configuration → SSL setings category to Configure Apache to use Combined cert and CA file or Cert file only. Which option should one choose? Default is ‘Decide Automatically’.
This issue should fixed later today for all new installs!
This is a known bug and will be fixed in the new Virtualmin 7.50.0 release! @Jamie, is there anything else holding back the new release? We need to fix ongoing bugs.
In the meantime, it’s possible to address it using the following patch:
Also, I have not been able to install an SSL certificate for any domains after a transfer. The DNS entries are all correct and everything was updated for some time before I tried a certificate request.
Well, I did that. It took hardly a second. I rebooted and then transferred one more website from another VPS. No Apache errors. No SSL errors at all. SSL certificate request went ahead smoothly and got the certificate installed fast, as it always used to be. Even with the websites I had transferred earlier.
Thank you very much for the ultra fast response. You are very kind.
Also, any way I should be able to check if everything is working fine after I ran that command - sudo find /etc/apache2 -type f -exec sed -i ‘/SSLCACertificateFile/d’ {} + ?
Because I wont even know if something is broken till some customer complains.
I was able to get to the root of the problem. It was the firewall at Hostinger. One has to set up the firewall in addition to the Virtualmin firewall. It resolved the email issues.
If you try to connect using the openssl command to your domain, does it work? - Yes, it does.
It seems Apache2 is listening on port 443. Got that by running sudo netstat -lntup
This thread is pretty chaotic and hard to follow. You’ve talked about Webmin, Apache and email, all different issues. And, at least two different problems in Apache. Please focus on one problem per topic. (FAQ - Virtualmin Community)
This error:
Means the browser is unhappy with the certificate it received. Probably means it received a self-signed certificate.
So, you need to look at the specific site where that log appears. Don’t be vague about it or keep changing random things unrelated to the problem hoping it does something good. The browser made a request to a specific domain. You need to browse to that domain and look at the cert you receive. This could be a case of “the wrong site shows up” (Troubleshooting Websites | Virtualmin — Open Source Web Hosting Control Panel) as that is common with Apache if you have misconfigured IPv6 or have multiple IPs misconfigured or…well, there’s a wide variety of ways to get this behavior.
