Howdy all,
I did some more updates and manual fixes for a variety of PHP 5->7 upgrade issues. But, in the process introduced a new problem with the shop that I haven’t figured out a solution for (I was trying to solve an issue with the shop by upgrading all of the Drupal commerce modules…and created a much worse one).
So, if you have any orders, you may see a bunch of new ones (hundreds of them). Don’t panic. I’ve turned off automatic billing, so you won’t be charged, and I’ll figure out how to remove the extraneous orders so the orders page is cleaner.
Cheers,
Joe
