Moodle V5.0 script
Just wondering if or when the script will be updated to the latest version of Moodle?
Currently, I run 4.5.4, but Moodle mentioned there are updates for 5.0.
Warm regards
Rob Oudendijk
I had a look at there site, maybe if you want to upgrade it maybe best done manually. But the script for new install is out of date.
and the software offers no upgrade as well
Must be a major upgrade.
For checking. V5.0 is a serious update,
Warm regards,
Rob
Moodle 5 update in Virtualmin will arrive shortly!
Today tested the availability for the new script and i got this error.
Failed to install web app : None of the available PHP versions (8.1.2) are at or above 8.2
Regards
Rob Oudendijk
Have you switched to 8.2 or higher?
Stefan,
Thanks for the suggestion. I installed PHP8.2 and all works now. :slight_smile:
Updating now.
Hugs and peace,
Rob
