I have nodejs running successfully using the Virtualmin install script Node.js. When I try to install Letsencrypt for this site it fails but on other domains I tested on the same server Letsencrypt works fine. I suspect since the connection is being proxied using mongrel3000, the Letsencrypt validation process fails to complete. Has anyone gotten this to work successfully using Letsencrypt and how did you do it?
