Failed to install mailbox new signup module cause the server doesn’t have “The Authen::Captcha Perl” module installed.
The problem is that in Yum or RPMfind there’s no module like this one.
I am not able to find it.
May I have some hints about it ?
You may just need to pull it down from Perl’s CPAN repository.
Virtualmin can help with that – if you go into Webmin -> Others -> Perl Modules, click the Install Module tab, and have it install "Authen::Captcha" from CPAN.
I mean, one option is to install it from the command line, using:
perl -MCPAN -e ‘install Authen::Captcha’
However, it should work from within Virtualmin, and the fact that it only presents you with that error may be a bug (you may need to choose another mirror, but it should be able to help with that).
So if it still doesn’t work from within Virtualmin today (maybe the mirror is back up), I would recommend filing a bug in the Bugs and Issues tracker.
I reinstalled webmin module to manage Perl Modules
If I try to install Authen::Captcha always get an error, installation failed.
The problem is that I need dependencies
Math::Trig Digest::MD5 File::Spec GD File::Basename
And GD or libgd that always fail to install correctly
dunno why
I have tried with manual installation with cpan shell but i get same errors
Okay, it looks like you’re missing the “gd-devel” package. Try installing that using apt or yum, and you should be able to install the Perl module.
Why?
I’m very much opposed to superstitious reinstallations. If you don’t know why you’re doing something…don’t do it.
Reinstalling most Webmin modules is generally pretty harmless, but in some cases (like Virtualmin) it could be dramatic (like losing all of your virtual server meta-data), and if you don’t have good backups seriously stressful and time-consuming.
So this has nothing to do with the Webmin module. If cpan doesn’t work on your system, then Webmin obviously can’t use cpan to install CPAN modules.
I believe Eric has you covered on why the module is failing to actually build. You’re missing necessary library header files. This is why I recommend using yum or apt-get to install Perl modules, rather than CPAN or the Webmin module. It’ll install the non-Perl dependencies for you. Though it looks like perl-GD isn’t provided on CentOS/RHEL, only on Fedora. That’s kind of annoying. Debian and Ubuntu also have packages for it, I think.
centos has no clue about this libgd, been trying to install authen captch soooo many times myself.
though GD is installed and even imagemagick, i cant grasp why this authen::captcha cant make use of stuff thats already there
@ronald: Not sure if you are still having an issue with Authen::Captcha. I was able to get it to install via CPAN in Webmin by first running ‘yum install gcc’. Hope this helps someone.
Notice: Type perl Makefile.PL -h for command-line option summary.
Configuring for libgd version 2.0.28.
Checking for stray libgd header files…none found.
Included Features: GD_XPM GD_JPEG GD_FREETYPE GD_PNG GD_GIF
GD library used from: /usr
Checking if your kit is complete…
Looks good
Writing Makefile for GD
/usr/bin/perl “-Iblib/arch” “-Iblib/lib” GD/Image.pm.PLS GD/Image.pm
Extracting Image.pm (with variable substitutions)
cp GD/Polyline.pm blib/lib/GD/Polyline.pm
cp qd.pl blib/lib/qd.pl
cp GD/Image.pm blib/lib/GD/Image.pm
cp GD.pm blib/lib/GD.pm
AutoSplitting blib/lib/GD.pm (blib/lib/auto/GD)
cp GD/Simple.pm blib/lib/GD/Simple.pm
cp GD/Polygon.pm blib/lib/GD/Polygon.pm
/usr/bin/perl /usr/lib/perl5/5.8.5/ExtUtils/xsubpp -typemap /usr/lib/perl5/5.8.5/ExtUtils/typemap -
typemap typemap GD.xs > GD.xsc && mv GD.xsc GD.c
gcc -c -I/usr/include -D_REENTRANT -D_GNU_SOURCE -DDEBUGGING -fno-strict-aliasing -pipe -I/usr/loca
l/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -g -pipe -m32 -march=i3
86 -mtune=pentium4 -DVERSION="2.41" -DXS_VERSION="2.41" -fPIC “-I/usr/lib/perl5/5.8.5/i386-lin
ux-thread-multi/CORE” -DHAVE_JPEG -DHAVE_FT -DHAVE_XPM -DHAVE_GIF -DHAVE_PNG GD.c
GD.xs:7:16: gd.h: No such file or directory
GD.xs:8:21: gdfontg.h: No such file or directory
GD.xs:9:21: gdfontl.h: No such file or directory
GD.xs:10:22: gdfontmb.h: No such file or directory
GD.xs:11:21: gdfonts.h: No such file or directory
GD.xs:12:21: gdfontt.h: No such file or directory
GD.xs:340: error: syntax error before “GD__Image”
GD.xs:340: warning: data definition has no type or storage class
GD.xs:341: error: syntax error before “GD__Font”
GD.xs:341: warning: data definition has no type or storage class
GD.xs:383: error: syntax error before “gdIOCtx”
GD.xs:383: warning: no semicolon at end of struct or union
GD.xs:387: error: syntax error before ‘}’ token
GD.xs:387: warning: data definition has no type or storage class
GD.xs:391: error: syntax error before “ctx”
GD.xs: In function bufGetC': GD.xs:392: error: ctx’ undeclared (first use in this function)
GD.xs:392: error: (Each undeclared identifier is reported only once
GD.xs:392: error: for each function it appears in.)
GD.xs:394: error: dereferencing pointer to incomplete type
GD.xs:395: error: dereferencing pointer to incomplete type
GD.xs: At top level:
GD.xs:398: error: syntax error before “ctx”
GD.xs: In function bufGetBuf': GD.xs:399: error: ctx’ undeclared (first use in this function)
GD.xs:402: error: dereferencing pointer to incomplete type
GD.xs:403: error: len' undeclared (first use in this function) GD.xs:409: error: buf’ undeclared (first use in this function)
GD.xs:409: error: dereferencing pointer to incomplete type
GD.xs:410: error: dereferencing pointer to incomplete type
GD.xs:414: error: syntax error before “ctx”
GD.xs: In function bufSeek': GD.xs:415: error: ctx’ undeclared (first use in this function)
GD.xs:416: error: dereferencing pointer to incomplete type
GD.xs:417: error: dereferencing pointer to incomplete type
GD.xs:418: error: dereferencing pointer to incomplete type
GD.xs:422: error: syntax error before “ctx”
GD.xs: In function bufTell': GD.xs:423: error: ctx’ undeclared (first use in this function)
GD.xs:424: error: dereferencing pointer to incomplete type
GD.xs:427: error: syntax error before “ctx”
GD.xs: In function bufFree': GD.xs:428: error: ctx’ undeclared (first use in this function)
GD.xs:431: error: syntax error before ‘*’ token
GD.xs: In function newDynamicCtx': GD.xs:434: error: syntax error before ')' token GD.xs:434: error: syntax error before ')' token GD.xs:436: error: dereferencing pointer to incomplete type GD.xs:437: error: dereferencing pointer to incomplete type GD.xs:438: error: dereferencing pointer to incomplete type GD.xs:440: error: dereferencing pointer to incomplete type GD.xs:441: error: dereferencing pointer to incomplete type GD.xs:442: error: dereferencing pointer to incomplete type GD.xs:443: error: dereferencing pointer to incomplete type GD.xs:444: error: dereferencing pointer to incomplete type GD.xs:445: error: dereferencing pointer to incomplete type GD.xs:446: error: dereferencing pointer to incomplete type GD.xs:447: error: gdIOCtx’ undeclared (first use in this function)
GD.xs:447: error: syntax error before ‘)’ token
GD.xs:452: error: syntax error before “gd_cloneDim”
GD.xs:452: error: syntax error before “src”
GD.xs: In function gd_cloneDim': GD.xs:453: error: syntax error before "dst" GD.xs:454: error: src’ undeclared (first use in this function)
GD.xs:455: error: dst' undeclared (first use in this function) GD.xs:455: error: syntax error before "gdImageCreateTrueColor" GD.xs:458: error: syntax error before "gdImageCreatePalette" GD.xs:460: error: gdMaxColors’ undeclared (first use in this function)
GD.xs:476: error: syntax error before “src”
GD.xs: In function get_xformbounds': GD.xs:479: error: x’ undeclared (first use in this function)
GD.xs:479: error: src' undeclared (first use in this function) GD.xs:480: error: y’ undeclared (first use in this function)
GD.xs:481: error: x1' undeclared (first use in this function) GD.xs:483: error: x2’ undeclared (first use in this function)
GD.xs:484: error: y2' undeclared (first use in this function) GD.xs: At top level: GD.xs:505: error: syntax error before "image" GD.xs: In function gd_chkimagefmt’:
GD.xs:506: error: image' undeclared (first use in this function) GD.xs:507: error: truecolor’ undeclared (first use in this function)
GD.xs:509: error: gdMaxColors' undeclared (first use in this function) GD.c: In function XS_GD__Image__new’:
GD.c:611: error: syntax error before “RETVAL”
GD.xs:588: error: gdImagePtr' undeclared (first use in this function) GD.xs:588: error: syntax error before "theImage" GD.xs:592: error: theImage’ undeclared (first use in this function)
GD.xs:592: error: syntax error before “gdImageCreateTrueColor”
GD.xs:594: error: syntax error before “gdImageCreate”
GD.xs:596: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromPng’:
GD.c:669: error: syntax error before “RETVAL”
GD.xs:615: error: RETVAL' undeclared (first use in this function) GD.xs:615: error: syntax error before "gdImageCreateFromPng" GD.xs: In function XS_GD__Image_newFromPngData’:
GD.xs:627: error: gdIOCtx' undeclared (first use in this function) GD.xs:627: error: ctx’ undeclared (first use in this function)
GD.c:707: error: syntax error before “RETVAL”
GD.xs:639: error: RETVAL' undeclared (first use in this function) GD.xs:639: error: syntax error before "gdImageCreateFromPngCtx" GD.c: In function XS_GD__Image_newFromGdData’:
GD.c:742: error: syntax error before “RETVAL”
GD.xs:658: error: RETVAL' undeclared (first use in this function) GD.xs:658: error: syntax error before "gdImageCreateFromGdPtr" GD.c: In function XS_GD__Image_newFromGd2Data’:
GD.c:772: error: syntax error before “RETVAL”
GD.xs:672: error: RETVAL' undeclared (first use in this function) GD.xs:672: error: syntax error before "gdImageCreateFromGd2Ptr" GD.xs: In function XS_GD__Image_newFromJpegData’:
GD.xs:683: error: gdIOCtx' undeclared (first use in this function) GD.xs:683: error: ctx’ undeclared (first use in this function)
GD.c:812: error: syntax error before “RETVAL”
GD.xs:695: error: RETVAL' undeclared (first use in this function) GD.xs:695: error: syntax error before "gdImageCreateFromJpegCtx" GD.xs: In function XS_GD__Image_newFromWBMPData’:
GD.xs:710: error: gdIOCtx' undeclared (first use in this function) GD.xs:710: error: ctx’ undeclared (first use in this function)
GD.c:854: error: syntax error before “RETVAL”
GD.xs:722: error: RETVAL' undeclared (first use in this function) GD.xs:722: error: syntax error before "gdImageCreateFromWBMPCtx" GD.c: In function XS_GD__Image__newFromXbm’:
GD.c:884: error: syntax error before “RETVAL”
GD.xs:735: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromGd’:
GD.c:909: error: syntax error before “RETVAL”
GD.xs:745: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromGd2’:
GD.c:934: error: syntax error before “RETVAL”
GD.xs:755: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromJpeg’:
GD.c:970: error: syntax error before “RETVAL”
GD.xs:773: error: RETVAL' undeclared (first use in this function) GD.xs: In function XS_GD__Image__newFromWBMP’:
GD.xs:787: error: gdImagePtr' undeclared (first use in this function) GD.xs:787: error: syntax error before "img" GD.c:1002: error: syntax error before "RETVAL" GD.xs:790: error: img’ undeclared (first use in this function)
GD.xs:797: error: RETVAL' undeclared (first use in this function) GD.xs: In function XS_GD__Image_newFromXpm’:
GD.xs:807: error: gdImagePtr' undeclared (first use in this function) GD.xs:807: error: syntax error before "img" GD.c:1038: error: syntax error before "RETVAL" GD.xs:811: error: img’ undeclared (first use in this function)
GD.xs:811: error: syntax error before “gdImageCreateFromXpm”
GD.xs:818: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromGd2Part’:
GD.c:1080: error: syntax error before “RETVAL”
GD.xs:837: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image__newFromGif’:
GD.c:1116: error: syntax error before “RETVAL”
GD.xs:855: error: RETVAL' undeclared (first use in this function) GD.xs: In function XS_GD__Image_newFromGifData’:
GD.xs:865: error: gdIOCtx' undeclared (first use in this function) GD.xs:865: error: ctx’ undeclared (first use in this function)
GD.c:1152: error: syntax error before “RETVAL”
GD.xs:877: error: RETVAL' undeclared (first use in this function) GD.xs:877: error: syntax error before "gdImageCreateFromGifCtx" GD.c: In function XS_GD__Image_DESTROY’:
GD.c:1179: error: syntax error before “image”
GD.c:1183: error: image' undeclared (first use in this function) GD.c:1183: error: called object is not a function GD.c: In function XS_GD__Image_STORABLE_freeze’:
GD.c:1203: error: syntax error before “image”
GD.c:1209: error: image' undeclared (first use in this function) GD.c:1209: error: called object is not a function GD.xs:903: error: GD2_FMT_COMPRESSED’ undeclared (first use in this function)
GD.xs:903: warning: assignment makes pointer from integer without a cast
GD.xs: In function XS_GD__Image_STORABLE_thaw': GD.xs:917: error: syntax error before "image" GD.xs:922: error: image’ undeclared (first use in this function)
GD.c: In function XS_GD__Image_png': GD.c:1267: error: syntax error before "image" GD.c:1274: error: image’ undeclared (first use in this function)
GD.c:1274: error: called object is not a function
GD.c: In function XS_GD__Image_jpeg': GD.c:1310: error: syntax error before "image" GD.c:1319: error: image’ undeclared (first use in this function)
GD.c:1319: error: called object is not a function
GD.c: In function XS_GD__Image_gifanimbegin': GD.c:1358: error: syntax error before "image" GD.c:1367: error: image’ undeclared (first use in this function)
GD.c:1367: error: called object is not a function
GD.c: In function XS_GD__Image_gifanimadd': GD.c:1409: error: syntax error before "image" GD.c:1415: error: syntax error before "previm" GD.c:1420: error: image’ undeclared (first use in this function)
GD.c:1420: error: called object is not a function
GD.c:1456: error: previm' undeclared (first use in this function) GD.c:1460: error: called object is not a function GD.c: In function XS_GD__Image_gifanimend’:
GD.c:1491: error: syntax error before “image”
GD.c:1496: error: image' undeclared (first use in this function) GD.c:1496: error: called object is not a function GD.c: In function XS_GD__Image_wbmp’:
GD.c:1526: error: syntax error before “image”
GD.c:1535: error: image' undeclared (first use in this function) GD.c:1535: error: called object is not a function GD.c: In function XS_GD__Image_gif’:
GD.c:1570: error: syntax error before “image”
GD.c:1578: error: image' undeclared (first use in this function) GD.c:1578: error: called object is not a function GD.c: In function XS_GD__Image_gd’:
GD.c:1611: error: syntax error before “image”
GD.c:1616: error: image' undeclared (first use in this function) GD.c:1616: error: called object is not a function GD.xs:1102: warning: assignment makes pointer from integer without a cast GD.c: In function XS_GD__Image_gd2’:
GD.c:1642: error: syntax error before “image”
GD.c:1647: error: image' undeclared (first use in this function) GD.c:1647: error: called object is not a function GD.xs:1117: error: GD2_FMT_COMPRESSED’ undeclared (first use in this function)
GD.xs:1117: warning: assignment makes pointer from integer without a cast
GD.c: In function XS_GD__Image_transparent': GD.c:1673: error: syntax error before "image" GD.c:1679: error: image’ undeclared (first use in this function)
GD.c:1679: error: called object is not a function
GD.c: In function XS_GD__Image_getBounds': GD.c:1706: error: syntax error before "image" GD.c:1710: error: image’ undeclared (first use in this function)
GD.c:1710: error: called object is not a function
GD.c: In function XS_GD__Image_isTrueColor': GD.c:1736: error: syntax error before "image" GD.c:1742: error: image’ undeclared (first use in this function)
GD.c:1742: error: called object is not a function
GD.c: In function XS_GD__Image_trueColorToPalette': GD.c:1763: error: syntax error before "image" GD.c:1769: error: image’ undeclared (first use in this function)
GD.c:1769: error: called object is not a function
GD.c:1781: error: gdMaxColors' undeclared (first use in this function) GD.c: In function XS_GD__Image_rgb’:
GD.c:1802: error: syntax error before “image”
GD.c:1807: error: image' undeclared (first use in this function) GD.c:1807: error: called object is not a function GD.c: In function XS_GD__Image_boundsSafe’:
GD.c:1835: error: syntax error before “image”
GD.c:1843: error: image' undeclared (first use in this function) GD.c:1843: error: called object is not a function GD.c: In function XS_GD__Image_getPixel’:
GD.c:1866: error: syntax error before “image”
GD.c:1874: error: image' undeclared (first use in this function) GD.c:1874: error: called object is not a function GD.c: In function XS_GD__Image_setPixel’:
GD.c:1895: error: syntax error before “image”
GD.c:1902: error: image' undeclared (first use in this function) GD.c:1902: error: called object is not a function GD.c: In function XS_GD__Image_copyRotate90’:
GD.c:1922: error: syntax error before “src”
GD.c:1927: error: src' undeclared (first use in this function) GD.c:1927: error: called object is not a function GD.xs:1240: error: syntax error before "dst" GD.xs:1242: error: dst’ undeclared (first use in this function)
GD.xs:1242: error: syntax error before “gd_cloneDim”
GD.xs:1246: error: invalid lvalue in assignment
GD.xs:1249: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyRotate180’:
GD.c:1959: error: syntax error before “src”
GD.c:1964: error: src' undeclared (first use in this function) GD.c:1964: error: called object is not a function GD.xs:1261: error: syntax error before "dst" GD.xs:1263: error: dst’ undeclared (first use in this function)
GD.xs:1263: error: syntax error before “gd_cloneDim”
GD.xs:1267: error: invalid lvalue in assignment
GD.xs:1270: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyRotate270’:
GD.c:1996: error: syntax error before “src”
GD.c:2001: error: src' undeclared (first use in this function) GD.c:2001: error: called object is not a function GD.xs:1282: error: syntax error before "dst" GD.xs:1284: error: dst’ undeclared (first use in this function)
GD.xs:1284: error: syntax error before “gd_cloneDim”
GD.xs:1288: error: invalid lvalue in assignment
GD.xs:1291: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyFlipHorizontal’:
GD.c:2033: error: syntax error before “src”
GD.c:2038: error: src' undeclared (first use in this function) GD.c:2038: error: called object is not a function GD.xs:1303: error: syntax error before "dst" GD.xs:1305: error: dst’ undeclared (first use in this function)
GD.xs:1305: error: syntax error before “gd_cloneDim”
GD.xs:1309: error: invalid lvalue in assignment
GD.xs:1312: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyFlipVertical’:
GD.c:2070: error: syntax error before “src”
GD.c:2075: error: src' undeclared (first use in this function) GD.c:2075: error: called object is not a function GD.xs:1324: error: syntax error before "dst" GD.xs:1326: error: dst’ undeclared (first use in this function)
GD.xs:1326: error: syntax error before “gd_cloneDim”
GD.xs:1330: error: invalid lvalue in assignment
GD.xs:1333: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyTranspose’:
GD.c:2107: error: syntax error before “src”
GD.c:2112: error: src' undeclared (first use in this function) GD.c:2112: error: called object is not a function GD.xs:1345: error: syntax error before "dst" GD.xs:1347: error: dst’ undeclared (first use in this function)
GD.xs:1347: error: syntax error before “gd_cloneDim”
GD.xs:1351: error: invalid lvalue in assignment
GD.xs:1354: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_copyReverseTranspose’:
GD.c:2144: error: syntax error before “src”
GD.c:2149: error: src' undeclared (first use in this function) GD.c:2149: error: called object is not a function GD.xs:1366: error: syntax error before "dst" GD.xs:1368: error: dst’ undeclared (first use in this function)
GD.xs:1368: error: syntax error before “gd_cloneDim”
GD.xs:1372: error: invalid lvalue in assignment
GD.xs:1375: error: RETVAL' undeclared (first use in this function) GD.c: In function XS_GD__Image_rotate180’:
GD.c:2181: error: syntax error before “src”
GD.c:2185: error: src' undeclared (first use in this function) GD.c:2185: error: called object is not a function GD.xs:1392: error: invalid lvalue in assignment GD.xs:1392: error: invalid lvalue in assignment GD.xs:1393: error: invalid lvalue in assignment GD.xs:1393: error: invalid lvalue in assignment GD.c: In function XS_GD__Image_copyRotated’:
GD.c:2214: error: syntax error before “dst”
GD.c:2226: error: dst' undeclared (first use in this function) GD.c:2226: error: called object is not a function GD.c:2233: error: src’ undeclared (first use in this function)
GD.c:2233: error: called object is not a function
GD.c: In function XS_GD__Image_flipHorizontal': GD.c:2257: error: syntax error before "src" GD.c:2261: error: src’ undeclared (first use in this function)
GD.c:2261: error: called object is not a function
GD.xs:1431: error: invalid lvalue in assignment
GD.xs:1432: error: invalid lvalue in assignment
GD.c: In function XS_GD__Image_flipVertical': GD.c:2290: error: syntax error before "src" GD.c:2294: error: src’ undeclared (first use in this function)
GD.c:2294: error: called object is not a function
GD.xs:1449: error: invalid lvalue in assignment
GD.xs:1450: error: invalid lvalue in assignment
GD.c: In function XS_GD__Image_line': GD.c:2323: error: syntax error before "image" GD.c:2332: error: image’ undeclared (first use in this function)
GD.c:2332: error: called object is not a function
GD.c: In function XS_GD__Image_dashedLine': GD.c:2352: error: syntax error before "image" GD.c:2361: error: image’ undeclared (first use in this function)
GD.c:2361: error: called object is not a function
GD.c: In function XS_GD__Image_openPolygon': GD.c:2381: error: syntax error before "image" GD.c:2387: error: image’ undeclared (first use in this function)
GD.c:2387: error: called object is not a function
GD.xs:1494: error: gdPointPtr' undeclared (first use in this function) GD.xs:1494: error: syntax error before "polyptr" GD.xs:1510: error: polyptr’ undeclared (first use in this function)
GD.xs:1510: error: syntax error before “Perl_safesysmalloc”
GD.c: In function XS_GD__Image_unclosedPolygon': GD.c:2452: error: syntax error before "image" GD.c:2458: error: image’ undeclared (first use in this function)
GD.c:2458: error: called object is not a function
GD.xs:1550: error: gdPointPtr' undeclared (first use in this function) GD.xs:1550: error: syntax error before "polyptr" GD.c: In function XS_GD__Image_filledPolygon’:
GD.c:2526: error: syntax error before “image”
GD.c:2532: error: image' undeclared (first use in this function) GD.c:2532: error: called object is not a function GD.xs:1609: error: gdPointPtr’ undeclared (first use in this function)
GD.xs:1609: error: syntax error before “polyptr”
GD.xs:1625: error: polyptr' undeclared (first use in this function) GD.xs:1625: error: syntax error before "Perl_safesysmalloc" GD.c: In function XS_GD__Image_rectangle’:
GD.c:2597: error: syntax error before “image”
GD.c:2606: error: image' undeclared (first use in this function) GD.c:2606: error: called object is not a function GD.c: In function XS_GD__Image_filledRectangle’:
GD.c:2626: error: syntax error before “image”
GD.c:2635: error: image' undeclared (first use in this function) GD.c:2635: error: called object is not a function GD.c: In function XS_GD__Image_filledEllipse’:
GD.c:2655: error: syntax error before “image”
GD.c:2664: error: image' undeclared (first use in this function) GD.c:2664: error: called object is not a function GD.c: In function XS_GD__Image_arc’:
GD.c:2684: error: syntax error before “image”
GD.c:2695: error: image' undeclared (first use in this function) GD.c:2695: error: called object is not a function GD.c: In function XS_GD__Image_filledArc’:
GD.c:2715: error: syntax error before “image”
GD.c:2727: error: image' undeclared (first use in this function) GD.c:2727: error: called object is not a function GD.c: In function XS_GD__Image_fillToBorder’:
GD.c:2753: error: syntax error before “image”
GD.c:2761: error: image' undeclared (first use in this function) GD.c:2761: error: called object is not a function GD.c: In function XS_GD__Image_fill’:
GD.c:2781: error: syntax error before “image”
GD.c:2788: error: image' undeclared (first use in this function) GD.c:2788: error: called object is not a function GD.c: In function XS_GD__Image_setBrush’:
GD.c:2808: error: syntax error before “image”
GD.c:2813: error: image' undeclared (first use in this function) GD.c:2813: error: called object is not a function GD.c:2820: error: brush’ undeclared (first use in this function)
GD.c:2820: error: called object is not a function
GD.c: In function XS_GD__Image_setTile': GD.c:2840: error: syntax error before "image" GD.c:2845: error: image’ undeclared (first use in this function)
GD.c:2845: error: called object is not a function
GD.c:2852: error: tile' undeclared (first use in this function) GD.c:2852: error: called object is not a function GD.c: In function XS_GD__Image_setThickness’:
GD.c:2872: error: syntax error before “image”
GD.c:2877: error: image' undeclared (first use in this function) GD.c:2877: error: called object is not a function GD.c: In function XS_GD__Image_setStyle’:
GD.c:2897: error: syntax error before “image”
GD.c:2901: error: image' undeclared (first use in this function) GD.c:2901: error: called object is not a function GD.c: In function XS_GD__Image_colorAllocate’:
GD.c:2933: error: syntax error before “image”
GD.c:2942: error: image' undeclared (first use in this function) GD.c:2942: error: called object is not a function GD.c: In function XS_GD__Image_colorAllocateAlpha’:
GD.c:2963: error: syntax error before “image”
GD.c:2973: error: image' undeclared (first use in this function) GD.c:2973: error: called object is not a function GD.c: In function XS_GD__Image_colorClosest’:
GD.c:2994: error: syntax error before “image”
GD.c:3003: error: image' undeclared (first use in this function) GD.c:3003: error: called object is not a function GD.c: In function XS_GD__Image_colorClosestAlpha’:
GD.c:3024: error: syntax error before “image”
GD.c:3034: error: image' undeclared (first use in this function) GD.c:3034: error: called object is not a function GD.c: In function XS_GD__Image_colorClosestHWB’:
GD.c:3055: error: syntax error before “image”
GD.c:3064: error: image' undeclared (first use in this function) GD.c:3064: error: called object is not a function GD.c: In function XS_GD__Image_colorExact’:
GD.c:3085: error: syntax error before “image”
GD.c:3094: error: image' undeclared (first use in this function) GD.c:3094: error: called object is not a function GD.c: In function XS_GD__Image_colorExactAlpha’:
GD.c:3115: error: syntax error before “image”
GD.c:3125: error: image' undeclared (first use in this function) GD.c:3125: error: called object is not a function GD.c: In function XS_GD__Image_colorResolve’:
GD.c:3146: error: syntax error before “image”
GD.c:3155: error: image' undeclared (first use in this function) GD.c:3155: error: called object is not a function GD.c: In function XS_GD__Image_colorResolveAlpha’:
GD.c:3176: error: syntax error before “image”
GD.c:3186: error: image' undeclared (first use in this function) GD.c:3186: error: called object is not a function GD.c: In function XS_GD__Image_colorsTotal’:
GD.c:3207: error: syntax error before “image”
GD.c:3213: error: image' undeclared (first use in this function) GD.c:3213: error: called object is not a function GD.c: In function XS_GD__Image_interlaced’:
GD.c:3236: error: syntax error before “image”
GD.c:3242: error: image' undeclared (first use in this function) GD.c:3242: error: called object is not a function GD.c: In function XS_GD__Image_compare’:
GD.c:3269: error: syntax error before “image1”
GD.c:3276: error: image1' undeclared (first use in this function) GD.c:3276: error: called object is not a function GD.c:3283: error: image2’ undeclared (first use in this function)
GD.c:3283: error: called object is not a function
GD.c: In function XS_GD__Image_colorDeallocate': GD.c:3304: error: syntax error before "image" GD.c:3309: error: image’ undeclared (first use in this function)
GD.c:3309: error: called object is not a function
GD.c: In function XS_GD__Image_copy': GD.c:3329: error: syntax error before "destination" GD.c:3340: error: destination’ undeclared (first use in this function)
GD.c:3340: error: called object is not a function
GD.c:3347: error: source' undeclared (first use in this function) GD.c:3347: error: called object is not a function GD.c: In function XS_GD__Image_copyResized’:
GD.c:3367: error: syntax error before “destination”
GD.c:3380: error: destination' undeclared (first use in this function) GD.c:3380: error: called object is not a function GD.c:3387: error: source’ undeclared (first use in this function)
GD.c:3387: error: called object is not a function
GD.c: In function XS_GD__Image_copyResampled': GD.c:3407: error: syntax error before "destination" GD.c:3420: error: destination’ undeclared (first use in this function)
GD.c:3420: error: called object is not a function
GD.c:3427: error: source' undeclared (first use in this function) GD.c:3427: error: called object is not a function GD.c: In function XS_GD__Image_copyMerge’:
GD.c:3447: error: syntax error before “destination”
GD.c:3459: error: destination' undeclared (first use in this function) GD.c:3459: error: called object is not a function GD.c:3466: error: source’ undeclared (first use in this function)
GD.c:3466: error: called object is not a function
GD.c: In function XS_GD__Image_copyMergeGray': GD.c:3486: error: syntax error before "destination" GD.c:3498: error: destination’ undeclared (first use in this function)
GD.c:3498: error: called object is not a function
GD.c:3505: error: source' undeclared (first use in this function) GD.c:3505: error: called object is not a function GD.c: In function XS_GD__Image_paletteCopy’:
GD.c:3525: error: syntax error before “destination”
GD.c:3530: error: destination' undeclared (first use in this function) GD.c:3530: error: called object is not a function GD.c:3537: error: source’ undeclared (first use in this function)
GD.c:3537: error: called object is not a function
GD.c: In function XS_GD__Image_char': GD.c:3557: error: syntax error before "image" GD.c:3566: error: image’ undeclared (first use in this function)
GD.c:3566: error: called object is not a function
GD.c:3573: error: font' undeclared (first use in this function) GD.c:3573: error: called object is not a function GD.c: In function XS_GD__Image_charUp’:
GD.c:3593: error: syntax error before “image”
GD.c:3602: error: image' undeclared (first use in this function) GD.c:3602: error: called object is not a function GD.c:3609: error: font’ undeclared (first use in this function)
GD.c:3609: error: called object is not a function
GD.c: In function XS_GD__Image_string': GD.c:3629: error: syntax error before "image" GD.c:3638: error: image’ undeclared (first use in this function)
GD.c:3638: error: called object is not a function
GD.c:3645: error: font' undeclared (first use in this function) GD.c:3645: error: called object is not a function GD.c: In function XS_GD__Image_stringUp’:
GD.c:3665: error: syntax error before “image”
GD.c:3674: error: image' undeclared (first use in this function) GD.c:3674: error: called object is not a function GD.c:3681: error: font’ undeclared (first use in this function)
GD.c:3681: error: called object is not a function
GD.xs: In function XS_GD__Image_stringFT': GD.xs:2153: error: gdImagePtr’ undeclared (first use in this function)
GD.xs:2153: error: syntax error before “img”
GD.xs:2163: error: gdFTStringExtra' undeclared (first use in this function) GD.xs:2163: error: syntax error before "strex" GD.xs:2173: error: img’ undeclared (first use in this function)
GD.xs:2173: error: syntax error before “tmp”
GD.xs:2182: error: strex' undeclared (first use in this function) GD.xs:2186: error: gdFTEX_LINESPACE’ undeclared (first use in this function)
GD.xs:2190: error: gdFTEX_CHARMAP' undeclared (first use in this function) GD.xs:2192: error: gdFTEX_Unicode’ undeclared (first use in this function)
GD.xs:2194: error: gdFTEX_Shift_JIS' undeclared (first use in this function) GD.xs:2196: error: gdFTEX_Big5’ undeclared (first use in this function)
GD.xs:2217: warning: assignment makes pointer from integer without a cast
GD.xs:2221: warning: assignment makes pointer from integer without a cast
GD.c: In function XS_GD__Image_stringFTCircle': GD.c:3808: error: syntax error before "image" GD.c:3828: error: image’ undeclared (first use in this function)
GD.c:3828: error: called object is not a function
GD.c: In function XS_GD__Image_useFontConfig': GD.c:3873: error: syntax error before "image" GD.c:3883: error: image’ undeclared (first use in this function)
GD.c:3883: error: called object is not a function
GD.c: In function XS_GD__Image_alphaBlending': GD.c:3910: error: syntax error before "image" GD.c:3915: error: image’ undeclared (first use in this function)
GD.c:3915: error: called object is not a function
GD.c: In function XS_GD__Image_saveAlpha': GD.c:3935: error: syntax error before "image" GD.c:3940: error: image’ undeclared (first use in this function)
GD.c:3940: error: called object is not a function
GD.c: In function XS_GD__Image_clip': GD.c:3961: error: syntax error before "image" GD.c:3969: error: image’ undeclared (first use in this function)
GD.c:3969: error: called object is not a function
GD.c: In function XS_GD__Image_setAntiAliased': GD.c:4001: error: syntax error before "image" GD.c:4006: error: image’ undeclared (first use in this function)
GD.c:4006: error: called object is not a function
GD.c: In function XS_GD__Image_setAntiAliasedDontBlend': GD.c:4026: error: syntax error before "image" GD.c:4032: error: image’ undeclared (first use in this function)
GD.c:4032: error: called object is not a function
GD.xs: In function XS_GD__Font_load': GD.xs:2383: error: gdFontPtr’ undeclared (first use in this function)
GD.xs:2383: error: syntax error before “font”
GD.c:4069: error: syntax error before “RETVAL”
GD.xs:2395: error: font' undeclared (first use in this function) GD.xs:2395: error: syntax error before "Perl_safesysmalloc" GD.xs:2426: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_DESTROY': GD.c:4132: error: syntax error before "self" GD.c:4136: error: self’ undeclared (first use in this function)
GD.c:4136: error: called object is not a function
GD.c: In function XS_GD__Font_Small': GD.c:4164: error: syntax error before "RETVAL" GD.xs:2453: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_Large': GD.c:4190: error: syntax error before "RETVAL" GD.xs:2464: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_Giant': GD.c:4216: error: syntax error before "RETVAL" GD.xs:2475: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_MediumBold': GD.c:4242: error: syntax error before "RETVAL" GD.xs:2486: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_Tiny': GD.c:4268: error: syntax error before "RETVAL" GD.xs:2497: error: RETVAL’ undeclared (first use in this function)
GD.c: In function XS_GD__Font_nchars': GD.c:4293: error: syntax error before "font" GD.c:4299: error: font’ undeclared (first use in this function)
GD.c:4299: error: called object is not a function
GD.c: In function XS_GD__Font_offset': GD.c:4320: error: syntax error before "font" GD.c:4326: error: font’ undeclared (first use in this function)
GD.c:4326: error: called object is not a function
GD.c: In function XS_GD__Font_width': GD.c:4347: error: syntax error before "font" GD.c:4353: error: font’ undeclared (first use in this function)
GD.c:4353: error: called object is not a function
GD.c: In function XS_GD__Font_height': GD.c:4374: error: syntax error before "font" GD.c:4380: error: font’ undeclared (first use in this function)
GD.c:4380: error: called object is not a function
make: *** [GD.o] Error 1
[/code:1]
Looks good
[/code:1]
