I’m using Virtualmin control panel on my server. I am using WHMCS as a billing software. In WHMCS I have set up the server info correctly (hostname is mydomain.com, IP, nameservers, correct username and password) and I have checked the “Tick to use SSL Mode for Connections” checkbox. I have selected the option to “Automatically setup the product as soon as the first payment is received”. I am getting this error when a client makes an order and pays the invoice:
Error: Curl Error: 35 - error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
Basically it fails to create an account in the virtualmin.
What does the error mean? And how do I fix it?
