Basically I do not know why the files are not properly transloaded. I believe this could be PHP parsing problem. Anyone here knows what is the proper configuration to have Rapidleech work on Virtualmin?
I’m not familiar with that particular software – but what is the problem you’re having with it, specifically? You mentioned an issue with transcoding – are you seeing any errors? What about in the Apache logs, $HOME/logs/error_log… does anything show up in there?
If you haven’t already, you may want to look at the requirements they list on that site:
Not all of those are defaults on each distro… for example, Ubuntu’s memory_limit defaults to 32MB, whereas the above says it requires a limit higher than that.
Ok, I’ve managed fix the script a bit, but I’m facing output_buffering issue. By default it seems that mod_fcgid has this turned on. How can I overwrite it so that it will be turned off?
