Hi There,
I followed this tutorial https://www.digitalocean.com/community/tutorials/how-to-install-and-configure-mod_deflate-on-centos-7 and created a file under path
/etc/httpd/conf.d/mod_deflate.conf
<filesMatch "\.(js|html|css)$">
SetOutputFilter DEFLATE
</filesMatch>
Restarted the server, but the compression doesnt seems to be working, is there anything else I need to do to enable this.
Note: httpd -t -D DUMP_MODULES successfully results the module:
deflate_module (shared)
Appreciate your help.
ramin
September 29, 2020, 8:47pm
2
Try wrapping directives in mod_deflate.conf like this:
<IfModule mod_deflate.c>
</filesMatch>
</IfModule>
Or try it another way:
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
AddOutputFilterByType DEFLATE application/x-font
AddOutputFilterByType DEFLATE application/x-font-opentype
AddOutputFilterByType DEFLATE application/x-font-otf
AddOutputFilterByType DEFLATE application/x-font-truetype
AddOutputFilterByType DEFLATE application/x-font-ttf
AddOutputFilterByType DEFLATE application/x-javascript
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE font/opentype
AddOutputFilterByType DEFLATE font/otf
AddOutputFilterByType DEFLATE font/ttf
AddOutputFilterByType DEFLATE image/svg+xml
AddOutputFilterByType DEFLATE image/x-icon
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/javascript
AddOutputFilterByType DEFLATE text/json
AddOutputFilterByType DEFLATE text/md
AddOutputFilterByType DEFLATE text/pl
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE text/xml
</IfModule>
Hi @ramin thanks for the details, it worked and now the compression is enabled for the entire site. However the Ajax calls have stopped working, with this compression. Every time the ajax call is made it will freeze the request and the request will not go further, please find the below image.
Any idea what could be happening here.
I am using Codeignitor as the framework.
ramin
September 30, 2020, 2:50pm
4
Now you’re biting off more than I can chew.
My best guess is that in addition to DEFLATE directives in the <IfModule mod_deflate.c>
section, you need to work on headers for encoding types (mod_headers is surely loaded already). A common snafu is content that’s already compressed getting the gzip treatment a second or third time and something goes wrong, least of which is wasted CPU.
Search and research headers with mod_deflate. In your mod_deflate.conf you probably need something along the lines of…
</IfModule>
<IfModule mod_headers.c>
# Serve gzip compressed CSS and JS files if the client accepts gzip
RewriteCond "%{HTTP:Accept-encoding}" "gzip"
RewriteCond "%{REQUEST_FILENAME}\.gz" -s
RewriteRule "^(.*)\.(css|js)" "$1\.$2\.gz" [QSA]
# Serve correct content types and prevent double compression
RewriteRule "\.css\.gz$" "-" [T=text/css,E=no-gzip:1]
RewriteRule "\.js\.gz$" "-" [T=text/javascript,E=no-gzip:1]
<FilesMatch "(\.js\.gz|\.css\.gz)$">
# Serve correct encoding type
Header append Content-Encoding gzip
</FilesMatch>
</IfModule>
Just for grins copy/paste this snippet, restart Apache and see if Ajax calls stop crashing.
Yes it worked, thanks a lot. Really appreciated!!!
system
Closed
October 31, 2020, 11:18am
6
