Missing Perl Module?
OS type and version Ubuntu Linux 20.04.4
Webmin version 1.994
Virtualmin version 7.1-1
Following on from Amazon S3 alternatives for backup I’ve tried to take a look at the Amazon option in VirtualMin > Backup and Restore > Cloud Storage Providers, but receive the error:
Cloud storage provider Amazon S3 cannot be used : The Perl module S3::QueryStringAuthGenerator needed to communicate with Amazon’s S3 service is not installed. Use the Perl Modules page in Webmin to install it.
When I click the Perl Modules link in the error line, I get to an Install Module page which has the following error:
Failed to install module : Module S3::QueryStringAuthGenerator was not found in the CPAN modules list
Perl isn’t something I’ve ever tangled with and I can’t seem to find anything obvious in the UI to manage it, or CPAN. How can I resolve this issue?
Thanks,
Matt
PS: I did try Webmin > Tools > Perl Modules and clicking the “From CPAN” radio box and the associated icon that pops up a new window… however searching for “s3” brings up a large list, none of which match S3::QueryStringAuthGenerator
@MattWilcox,
libamazons3
There’s no match for that either - but I’m likely being too literal? Here’s the result list for “s3”, am I right thinking that the first result might be “the whole thing” then?
@MattWilcox,
I assumed you were installing via CLI, but using the GUI the first one would likely be the one.
Thanks. Pulled the trigger and that top option maps to
apt-get -y -f install libamazon-s3-perl
Seems to have worked - thank you!
