I successfully installed and configured csf/lf However, it does not appear in the Webmin system menu nor anywhere else. Reassign module in Webmin configuration does not include csf either. I can still reach this module through the index status page.
Thanks for help
I’m having the identical issue. Have you solved this problem? Thank you
Did you install the webmin module per the instructions in the CSF install readme? It shows up under webmin/system once installed. Just did fresh test install. The csf listing didn’t show up until I hit refresh modules.
