Hi
We have purchased a renewal for the following order “1658” (serial = 5556873) but probably miss a step to allocate the payment to the right order so it is always “expired”
How can we correct this?
Regards
Michele DEGLI ALBIZI
Hi
Regards
Yeah, sometimes the store isn’t able to apply the renewal automatically. If it hasn’t occurred yet, my suggestion would be to file a support request, using the Support link above. Then Jamie will be able to manually handle that renewal for you.
Thanks!
I can’t help you here unfortunately, you’ll need to file a support request using the Support link above
Once you do that, Jamie will be able to take care of that pretty quickly for you.
As an aside, you can tell your customer that warning only shows up for the root user, and you don’t lose any functionality.
