mike2
March 27, 2009, 7:00pm
1
I am receiving this error during installation. What do I need to do to get around this?
-http://software.virtualmin.com/gpl/rhel/5Server/x86_64/virtualmin-base-1.0-61.rh.noarch.rpm: [Errno 14] HTTP Error 404: Not Found
Trying other mirror.
Error Downloading Packages:
virtualmin-base-1.0-61.rh.noarch: failure: virtualmin-base-1.0-61.rh.noarch.rpm from virtualmin: [Errno 256] No more mirrors to try.
Eric
March 27, 2009, 7:05pm
2
Hmm, that looks like a bug! It’s mis-detecting your distro.
What I would do is file a bug report, include the above info, along with:
Your distro and version
The contents of your /etc/issue file
The output of "uname -a"
Thanks!
Eric
March 27, 2009, 8:09pm
3
Thanks… you’ll want to file that information in a bug report though – using the Bugs and Issues link below.
Joe or Jamie may need to tweak something in the install script.
Thanks!
mike2
March 27, 2009, 8:14pm
4
Will do. Being new to this… what level of severity should this be? Its holding me up but…
Eric
March 27, 2009, 8:17pm
5
Well, all the stuff that comes in is considered important. Almost to the point where it doesn’t matter
But, I’d just put the priority at how important it is to you, and they’ll figure out the rest!
It’s for an install, and it’s holding you up, to me that’s at least a “High”
mike2
March 27, 2009, 8:21pm
6
Dumb questions probably. How do you change the priority after its been put in the ticket system?
Joe
March 27, 2009, 8:30pm
7
Don’t bother. The people that need to know (me) have already seen it.
I’m working on it.
mike2
June 7, 2009, 12:48pm
8
Here you go.
Red Hat Enterprise Linux Server release 5.3 (Tikanga)
Kernel \r on an \m
Linux 218167-web3.zcreative.com 2.6.18-128.1.1.el5 #1 SMP Mon Jan 26 13:58:24 EST 2009 x86_64 x86_64 x86_64 GNU/Linux
mike2
9
Here you go.
Kernel \r on an \m
