I tried to create my first virtual domain with mail server, web server, dns
server, and ssl web server, but I messed up the settings so I deleted the entire
virtual server instance. I then tried to re-create the virtual server instance
from scratch, but I keep on getting the same errors below. Any suggestions on
how I can completely remove the pieces of this virtual domain so that I can
re-create it all from scratch? I also checked for the
"/home/rbkpublishing.com/logs/access_log", and it is true that it does not
exist, because "/home/rbkpublishing/logs/access_log" was created by the program
automatically. Well, thank you for your help, take care, and have a nice day!
Ron
Setting Up Virtual Server
In domain rbkpublishing.com
Creating home directory …
… done
Creating Unix group rbkpublishing …
… done
Creating Unix user rbkpublishing …
… done
Adding new DNS zone …
… done
Adding to email domains list …
… done
Adding new virtual website …
… Apache website failed! : Failed to open
/home/rbkpublishing.com/logs/access_log for writing : No such file or directory
at …/web-lib-funcs.pl line 820.
Setting up scheduled Webalizer reporting …
… done
Creating SSL certificate and private key …
… done
Adding new SSL virtual website …
… done
Setting up log file rotation …
… done
Creating MySQL login …
… MySQL database failed! : SQL insert into user (host, user, password) values
(‘localhost’, ‘rbkpublishing’, password(‘test’)) failed : Duplicate entry
‘localhost-rbkpublishing’ for key 1 at …/web-lib-funcs.pl line 820.
Creating Webmin user …
… done
Adding DAV directives to website configuration …
… done
Setting up AWstats reporting …
… done
Re-starting DNS server …
… done
Stopping and re-starting web server …
… not running!
Re-starting Webmin …
… done
Applying web server configuration …
… not running!
Adding virtual IP interface for 67.141.195.229 …
… created interface eth0:1
Saving server details …
… done
