Metadata file does not match checksum
I’m trying to install a RED5 server
I’ve just installed the java files and I’m now moving to the ant and subversion.
Since I use Centos, I use the following command:
yum install ant subversion
However I get the result:
–> Running transaction check
—> Package java-1.4.2-gcj-compat.x86_64 0:1.4.2.0-40jpp.115 set to be updated
virtualmin-universal/filelists | 899 kB 00:01
http://software.virtualmin.com/gpl/universal/repodata/filelists.xml.gz: [Errno -1] Metadata file does not match checksum
Trying other mirror.
Error: failure: repodata/filelists.xml.gz from virtualmin-universal: [Errno 256] No more mirrors to try.
What could the problem be, and how can I solve it?
Thanks :slight_smile:
What happens if you run a “yum clean all”, then attempt that installation again… do you receive the same error, or does it work properly?
Great help Eric! worked like a charm.
