hi support team,
please help me install mbstring in my virtualmin, i dont know which php version to use that has enabled this mbstring
my script need mb_substr() function enable to get it to work. and i already search google about this problem and i cant find it.
please guide my way.
thanks much
Eric
February 21, 2015, 5:13pm
2
You mentioned having two PHP versions installed, 5.3 and 5.4.
The PHP 5.4 version provided in the SCL repository doesn’t provide the mbstring module.
However, the php-mbstring package is provided by CentOS for PHP 5.3. You can install that by running the command “yum install php-mbstring”.
Would that work for you?
but the script i want to use doesnt support php version 5.3 it must be 5.4 or higher
can you help me get a working php version that mbstring enabled?
warp
February 23, 2015, 4:13pm
4
I’ve also this problem, i must install a script using mbstring on php 5.4 please do you have a solution ?
Thank you in advance,
Best regards
you can install php54-php-mbstring from webmin/system/Software Packages
Package from YUM - php54-php-mbstring will execute “yum install php54-php-mbstring”
that will work for PHP 5.4
If you want it working for PHP 5.3 “yum install php-mbstring”
