Maximum Upload Size (default is 16 B)
OS type and version Ubuntu 20.04
Webmin version 1.860
I have setup two Wordpress sites in Webmin/Virtualmin but I cant change the default “Maximum Upload Size (default is 16 B)”
I have changed in php.ini, wp-config.config and rebooted but its still not increasing, I have also updated the setting the Webmin default template for PHP and rebooted.
I am using php 7.4 and lost as to why this is happening
The status of your system is being checked to ensure that all enabled features are available and properly configured …
Your system has 3.8 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB
BIND DNS server is installed
Mail server Postfix is installed and configured
Postfix is configured to support per-domain outgoing IP addresses
Apache is installed
CGI scripts can be executed using suEXEC or FCGIwrap
Apache supports HTTP/2 on your system
The following PHP execution modes are available : cgi fcgid fpm
The following PHP versions are available : 7.4.3 (/bin/php-cgi7.4)
The following PHP-FPM versions are available : 7.4.3 (php7.4-fpm)
PHP versions have changed to 7.4 since last check. Regenerating any missing php.ini files
Apache is configured to host SSL websites
MariaDB 10.3.37 is installed and running
Logrotate is installed
SpamAssassin and Procmail are installed and configured for use
Plugin AWStats reporting is installed
Plugin Protected web directories is installed
Using network interface ens33 for virtual IPs
Default IPv4 address for virtual servers is 192.168.1.192
Both user and group quotas are enabled for home and email directories
All commands needed to create and restore backups are installed
The selected package management and update systems are installed
Chroot jails are available
… your system is ready for use by Virtualmin
Updating all Webmin users with new settings…
… done
Updating status collection job …
… done
Re-loading Webmin …
… done
standard issue with wordpress install. You need a increase your php max file upload.
you may need to increase memory alocation as well to allow the upload.
this is what I have
