Bonjour !
A little question :
Can I raise the default value of mail_max_userip_connections in etc/dovecot.conf file ?
The line that reads the value (10) seems to be commented (#), does a default value - unknown of me - already applies ?
Maximum number of IMAP connections allowed for a user from each IP address.
NOTE: The username is compared case-sensitively.
#mail_max_userip_connections = 10
Shall I raise the value and uncomment the line ?
I must restart Dovecot, right ? And something else, also ? Or AM I COMPLETELY WRONG ?
Thank you in advance for your kind help (I am not a paying user)
Eric
2
Sure! Just uncomment the line you mentioned, and change that to a higher number… 20 perhaps?
And then restart Dovecot, which you can do with this command as root:
/etc/init.d/dovecot restart
Fine, thank you very much for your kind attention and care.
The new way to do this, as of Centos 6.5 / Virtualmin 4.06 is in:
/etc/dovecot/conf.d/20-imap.conf
mail_max_userip_connections = 256
Also, in:
/etc/dovecot/dovecot.conf
Remove imaps and pop3s from the protocols settings (they are deprecated)
protocols = imap pop3
