So I’ve edited just about every PHP.INI file I can imagine on my server to contain the required statements to increase file upload limits on PHP web applications and none of them (PHPMyAdmin / Wordpress for example) show that any changes have been made and still prevent me from uploading files larger than the default.
Short of sliding a stick of dynamite into my mouth, does someone have a simple Step 1, Step 2, Step 3 guide to making sure all points needed are covered when configuring the server to allow this?
I found this post while looking for the same solution. I increased as per your suggestion at Services / PHP * Configuration / Resource Limits. Restarted Apache and still no change to phpmyadmin max upload. Stuck on 2MB. I also have edited all php.ini files. All out of options here.
I even increase from 2MB to 64M at MySQL Server Configuration / Maximum packet size.
