MariaDB not connecting from PHP
Webmin version 2.510
Virtualmin version 7.40.1
Webserver version Apache version 2.4.58
Just installed virtualmin GPL, created a virtualserver, a db and trying to connect.
I get ERROR 1044 (42000): Access denied for user 'user'@'localhost' to database 'database' from php or from cli
Is there anything I can try to debug/resolve? already tried to change the password, change/save allowed hosts…
are you connecting using database credentials ? (not the same with virtualmin user)
Virtual Server → Edit Databases → usernames / passwords
Bit more info, how did you create the database? In the GUI?
I can connect with no db selected
mysql -u user -p
I cannot connect with db selected:
mysql database -u user -p
So I do not think it’s a password problem?
It is the default db created from the virtual server creation, I just executed a dump.sql to migrate a wordpress site.
so this user has no permissions on this db. is this db associated with the specific virtual server?
Ok, so I am very shameful: the database was created with a littlebit changed name:
server name: domain-one.com
user name: domain-one (domain and db)
db: domain_one (see the underscore)
So using the right db name (I was firstly confused by the underscore), it works.
