I cant see that virtualmin has any kind of ‘1_Click_make_my_life_easy’ maintenance mode button
or maybe I just cant find it?
if there isnt - it would be a useful thing to have.
maybe return an error code for a site - 503 (or somesuch more appropriate) while I upload new stuff, sort the db and tidy up etc etc. If it didnt do it for my ip it would be good for testing too
mostly I dont need it, but just now I have a situation/code where my dev area doesnt easily work.
l.
edit:
rfc2616 says this about 503:
The server is currently unable to handle the request due to a
temporary overloading or maintenance of the server. The implication
is that this is a temporary condition which will be alleviated after
some delay. If known, the length of the delay MAY be indicated in a
Retry-After header. If no Retry-After is given, the client SHOULD
handle the response as it would for a 500 response.
so I guess option to set a Retry-After period would be useful
.htaccess… yep - but this upgrade also involves .htaccess!
I’ve done it via httpd.conf and previously with a complete separate public_html dir and mv pu…html pu…bak mv pu…new etc
but a nice little ‘1_Click_make_my_life_easy’ button would be ideal
I think maybe the response should be 503 unavailable and a Retry-After timeout option, but it oughtnt to be too hard to leave options as user select… at some point when there’s a minute obviously!
One idea Jamie had would be to use the redirects feature for this, in Server Configuration -> Website Redirects.
If you go in there, click “Add a new website redirect”, set the “Source URL Path” to “/”, set “Include sub-paths in redirect” to “Yes”, and just make the site redirect to a maintenance page you have somewhere.
