Command died with status 2: “/usr/local/mailman/mail/mailman post mailman”.
Command output: Group mismatch error. Mailman expected the mail wrapper
script to be executed as group “mailman”, but the system’s mail server
executed the mail script as group “nobody”. Try tweaking the mail server
to run the script as group “mailman”, or re-run configure, providing the
command line option `–with-mail-gid=nobody’.
Installing anything from source is a recipe for disaster. I can’t help. I’m not gonna try to figure out all the weird things that need to be sorted out with regard to permissions, ownership, paths, etc.
If you install from a package provided by your OS (they all have a mailman package), you will not have to figure all this nonsense out. Unless you really know what you’re doing you should never install anything from source (and if you really know what you’re doing, you won’t want to).
it is not installed via source it is installed with yum install mailman
you can try to logind and you will se
i have downloadet a mailman-2.1.34 src
a new configure like this:
./configure --with-mail-gid=nobody --with-cgi-gid=nobody
make install
cd /usr/local/mailman/bin ./mailmanctl restart
service postfix restart
and the web is still working with no errors and the maillist ist also working.
So the question is, is this ok the mailman has --with-mail-gid=nobody and --with-cgi-gid=nobody?
Packages do not put things in /usr/local
ok, i have cleaned my servers from the src mailman, the config is now this and all is working ![]()
