Mailman not found in Virtualmin
Hello.
I am using Virtualmin on two servers. The OS installed on both is Ubuntu 16.04 x64. I want to enable mailman but i cant find it anywhere. It is installed on systems, but its not listed in the System Settings - Features and Plugins. How do i add and enable mailman? I also tried starting it manualy and creating list but no luck.
hm… I think mailman was removed from glp a while ago… its still listed in pro version, and I think you can still install it manually with apt-get or whatever package management your os supports…, there is somewhere in this forums the post, but I cannot found it. - sorry about that. It should be apt-get install package and then you should be able to see it, however I cannot confirm that. I have that on my system still, but I’ve installed virtualmin gpl years ago. Best advice would be to ask virtualmin guys in tickets or pro tickets or just on irc channel on freenode - channel #virtualmin.
So no mailman in gpl version? I could swear that a while ago (few months) i had a problem when re-check failed on me on my test server, because mailman had no list and was unable to start and i had to disable mailman in Features and Plugins.
