Mail log files should have all this info but if you are looking something like cPanel Vmin doesnt have it so you need to dig log files, come up with some extra software or use custom script. While Vmin/Wmin have a lot of features still lack some of basic one what can be found in other software like cPanel or Plesk, well at least one with nice UI.
I hope in the future we can see dev team to work more on polishing out current software, pay more attention for each linux distro, more focus on eliminating obsolete modules and in the same time bring new one what are more essential or frequently used.
P.S. Tomorrow should be out new version of Vmin with some big/major changes so lets see what will bring to us.
@Eric: sherwinaval meant something similar what cPanel have where is much easier to check this options. It is true you can do the same with Vmin and mail logs but cPanel is more “eye candy” and probably easier to understand/find for most users.
Hi @andreychek ,
I am logged as root, and cannot find Search Mail Logs in Logs and Reports ??? Using Postfix. I can see maillog in Systemlogs, but missing search options.
What could be the problem ?
Logs and Reports -> Search Mail Logs (as root using GPL)
maillog (using postfix too) How do I enable this at least?
the only thing that’s mail related log in /var/log is procmail.log
the Cpanel feature is truly an eye-candy and it would be good if VM could have that too. However, i can read raw logs just fine and I wouldn’t access it all the time, at least just to check for spamming activities if there will be such.
