.> okay, user is created, but email frank@blah.com doesnt work, but frank.blah@blah.com works. Why it has to be *****.domain@domain.com , why not ****@domain.com?
Whenever your email user authenticates, you would need to login as that user’s username – you can see what the username is by looking at the “IMAP / POP3 / FTP login” column after clicking “Edit Users”.
Usernames are in the format “user.domain” by default. If you wish to change that default, you can do so by going into System Settings -> Server Templates -> Default -> Mail for Domain, and change the “Format for usernames that include domain” field to your desired format.
I can see the option at the button of that “Mail for Domain” setting (did you see the dropdown list?).
By the way, from virtualmin’s help:
The username@domain option is not recommended unless you are migrating users from another system that already uses it. The Postfix mail server has problems with SMTP authentication by users with an @ in the username, and requires that an extra Unix user be created for each mailbox for mail delivery to work.
