I set up a domain on my server (its still hosted somewhere else) with intention to move domain to new server
I set up email accounts too
when I email the domain through the server of course it gets picked up by this server and not the real server hosted elsewhere.
I wanted to stop this happening so rename the Virtual Server
however, the email is still not getting through this server. I checked the postfix file and found some entries so deleted them and rstarted postfix. email is still disappearing through server.
I suppose we need more info about this to venture a guess… What’s the domain in question, before and after the rename? What address are you trying to email?
What gets logged to /var/log/mail.log at the moment you send an email?
Okay, so the problem seems to have rested in Postfix’ virtual domain mapping, as I suspected.
When you renamed the domain, supposedly using Server Configuration -> Change Domain Name, did you set “Change mailbox name suffix” correctly? I just tested that, and when set to “Automatically chosen” or “Change to”, it will rename local user mailbox names as well as the domain. When set as “Leave as”, it will leave email addresses untouched.
So either you forgot to set that option, or your situation is different than what I tested, or you found a bug.
In any case, it’s generally not a good idea to just go and manually delete entries from server configuration files, at least as long as you don’t know precisely how they are integrated and managed from Virtualmin. Doing that can break things really good.
I now moved the server happygolf.co.uk back onto the server
some email accounts are working and some are not.
for example sales@happygolf.co.uk is not working
