I’ve recently configured a new setup with Cloudmin 6.8.kvm on CentOS6.3 and plan to use it to host a number of Ubuntu 12.04 KVM servers for various duties (mysql, mail apache etc).
The issue I’m struggling with right now is that creating a new instance is ignoring my request to use a particular LVM group. The host OS and files are in vg0 and I want new instances to use vg1 for some simple segregation and easier backups. vg0 is just 25GB, whereas vg1 is around 230GB and has no volumes created within it - both are using the same physical SSD.
For Cloudmin > Host Settings > KVM Host Settings > [my-host-system] > Create disk images in I’ve chosen vg1.
When creating a new instance, in the Advanced Options > Location for disk image, I’ve tried both Host System Default and LVM Logical Volume. Both fail with a message saying insufficient disk space, and the extra space required by the image suggests it’s trying to create the disk image in vg0 which is too small.
Am I missing some other setting somewhere or have I misunderstood the way I have set this up?
There is a bug that can cause the disk space on /kvm to be checked instead of the space in the LV when creating a new VM, and thus trigger this incorrect error.
How much disk space do you jave free on the filesystem that /kvm is on, and how big is the VM you are trying to create?
If it isn’t too much trouble, I’d really appreciate a patch. Although would that cause me issues with upgrading to new versions of Cloudmin when they are released?
