| SYSTEM INFORMATION | |
| OS type and version | REQUIRED |
| Webmin version | REQUIRED |
Have you set a root password ? If not you won’t be able to log in, maybe login with ssh and reset the root password or create a new user and add them to the sudo group. As you have not supplied the os you are using or in fact the version of webmin you have it could be difficult to advise you further
