hello friends that maybe the issue is a little out of this forum but maybe someone can help me with your experience, I am installing a Virtualmin on a centos with are connected to 3 different ISP and on one lan, also will use as a proxy, the question is basically the following one has worked in an environment like that? and worked load balance and failover for outgoing connections with Virtualmin I don’t have problems but with the connections I have a problem…
I don’t konw how to create routes and make scritp the firewall, anyone knows any solution that can help m
me?
tks for you help…
