On my VPS I would like to limit the CPU% and Memory of a certain virtual server. The site which is hosted at that virtual server has on some peak moments a very high load, which results in 100% CPU on both cores and high memory usage. This makes the sites hosted on other virtual servers slow or even inaccessible.
I found the following settings page in virtual min:
Processes and Limits
For domainname.tld:80
Processes and Limits for domainname.tld:80
Maximum request body size Default bytes Maximum XML request body size Default bytes
CPU resource limit Default
Soft limit
Soft limit Hard limit
Memory resource limit Default
Soft limit
Process limit Default
Soft limit
I already tried values like 70 or 80 in CPU resource limit, soft and hard. But when I do click apply and I do test the site with intense, it still goes to 100% CPU in top on both cores.
Memory limit does not work either.
How can I properly limit the resource usage of this site/domainname?
Thank you in advance.
