Well, one of the things you can look into are modifying the resource limits.
If you go into Administration Options -> Edit Resource Limits, you can tweak options for the maximum number of processes, process size, and CPU time.
I’d be interested in a good solution for identifying system resources consumed by users as well, but in the meantime, maybe the above is a start in the right direction
Sorry, I guess not – I’m constantly getting confused as to what is in which version – one of these days I’ll get a GPL install setup here so I can poke around with it more
However, what I believe it does is tweak /etc/security/limits.conf, which is something you can do manually as well. That’s an OS thing, not a Virtualmin thing.
