I want purchase minimal professional licence for Virtualmin an Cloudmin. I want to test them as a replacement for our solution so far. If your solution meets my requirements, can I easily move the licenses installed on the test system from this to the production system? Test systems will run on non-public IP addresses. Will there be a problem with such a scenario, or will it be OK?
Of course. We don’t lock the license to an address or whatever…you can move it whenever you want, without even letting us know about it (it checks the license and will detect usage on multiple systems, which gets logged in our end, but that doesn’t prevent installation). As long as you’re using the license in good faith, you should never even have to think about the license. It should just work.
