Hi
my first post here. Been using Virtualmin/Webmin on a Centos VPS since a while now and frequently visited this site for help. But for this issue I can’t find anything:
I tried to enable IP Access Control in Usermin/webmin configuration but there is a message which says:
IP access control using TCP-wrappers is not available, as the Authen::Libwrap Perl module is not installed. Click here to have Webmin automatically install the missing Perl module.
When I clicked the link the result was:
Making and installing Authen::Libwrap …
Untarring module file
Executing gunzip -c /tmp/.webmin/Authen-Libwrap-0.22.tar.gz | tar xvf - …
Authen-Libwrap-0.22
Authen-Libwrap-0.22/Build.PL
Authen-Libwrap-0.22/ChangeLog
Authen-Libwrap-0.22/example.pl
Authen-Libwrap-0.22/Makefile.PL
Authen-Libwrap-0.22/MANIFEST
Authen-Libwrap-0.22/META.yml
Authen-Libwrap-0.22/ppport.h
Authen-Libwrap-0.22/README
Authen-Libwrap-0.22/lib
Authen-Libwrap-0.22/lib/Authen
Authen-Libwrap-0.22/lib/Authen/Libwrap.pm
Authen-Libwrap-0.22/lib/Authen/Libwrap.xs
Authen-Libwrap-0.22/t
Authen-Libwrap-0.22/t/01_inline.t
Authen-Libwrap-0.22/t/02_maintainer.t
Authen-Libwrap-0.22/t/03_pod.t
tar: Read 2048 bytes from -
Authen-Libwrap-0.22/t/hosts.allow
Compiling module
Executing /usr/bin/perl Makefile.PL && make …
This module requires Module::Build to install itself.
Install Module::Build now from CPAN? [y] y
CPAN: Storable loaded ok
Going to read /root/.cpan/Metadata
Database was generated on Tue, 22 Nov 2011 03:31:07 GMT
CPAN: LWP::UserAgent loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
Going to read /root/.cpan/sources/authors/01mailrc.txt.gz
CPAN: Compress::Zlib loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/modules/02packages.details.txt.gz
Going to read /root/.cpan/sources/modules/02packages.details.txt.gz
Database was generated on Tue, 13 Dec 2011 14:38:48 GMT
There’s a new CPAN.pm version (v1.9800) available!
[Current version is v1.7602]
You might want to try
install Bundle::CPAN
reload cpan
without quitting the current session. It should be a seamless upgrade
while we are running…
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/modules/03modlist.data.gz
Going to read /root/.cpan/sources/modules/03modlist.data.gz
Going to write /root/.cpan/Metadata
Running install for module Module::Build::Compat
Running make for D/DA/DAGOLDEN/Module-Build-0.3800.tar.gz
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/id/D/DA/DAGOLDEN/Module-Build-0.3800.tar.gz
CPAN: Digest::MD5 loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/id/D/DA/DAGOLDEN/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/D/DA/DAGOLDEN/Module-Build-0.3800.tar.gz ok
Scanning cache /root/.cpan/build for sizes
Uncompressed /root/.cpan/sources/authors/id/D/DA/DAGOLDEN/Module-Build-0.3800.tar.gz successfully
Using Tar:/bin/tar xvf /root/.cpan/sources/authors/id/D/DA/DAGOLDEN/Module-Build-0.3800.tar:
Couldn’t untar /root/.cpan/sources/authors/id/D/DA/DAGOLDEN/Module-Build-0.3800.tar
Installation of Authen::Libwrap failed. Check the output above and try installing manually.
You can also install the module from CPAN with the command perl -MCPAN -e shell.
I searched the Virtualmin forum and found another entry which suggested to run
yum install tcp_wrappers
However, when I do so the result is:
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- base: mirror.switch.ch
- extras: mirror.switch.ch
- updates: mirror.silyus.net
Setting up Install Process
Package tcp_wrappers-7.6-40.7.el5.i386 already installed and latest version
Nothing to do
Could someone please point me to a solution for this?
Christian
