Letsencrypt Not Working Help
OS type and version REQUIRED
Webmin version REQUIRED
Virtualmin version REQUIRED
Webserver version REQUIRED
Hi
my lets encrypt was working fine and then just stopped here is my log fail constant and it stuck on auto renew how can i stop this and get my certificates running again
thank you in advance
2025-11-02 19:53:00,762:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 429 497
2025-11-02 19:53:00,762:DEBUG:acme.client:Received response:
HTTP 429
Server: nginx
Date: Sun, 02 Nov 2025 19:53:00 GMT
Content-Type: application/problem+json
Content-Length: 497
Connection: keep-alive
Boulder-Requester: 2583697836
Cache-Control: public, max-age=0, no-cache
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: pUutGg57RV_wxu3NALdf4PkT53Tb8_o_q-KArHr9YKeZGG2Metw
 "type": "urn:ietf:params:acme:error:rateLimited",
 "detail": "Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MCwiaWF0IjoxNzYyMTEzMTgwLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.dtblj-pAQhtGrSJtHbNoJtLH-d51lwsP2fXsMCx420U",
 "status": 429
2025-11-02 19:53:00,763:DEBUG:certbot._internal.log:Exiting abnormally:
 File "/bin/letsencrypt", line 33, in <module>
   sys.exit(load_entry_point('certbot==2.9.0', 'console_scripts', 'certbot')())
 File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
   return internal_main.main(cli_args)
 File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1894, in main
   return config.func(config, plugins)
 File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1600, in certonly
   lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
 File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
   lineage = le_client.obtain_and_enroll_certificate(domains, certname)
 File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 517, in obtain_and_enroll_certificate
   cert, chain, key, _ = self.obtain_certificate(domains)
 File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 428, in obtain_certificate
   orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names)
 File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 478, in _get_order_and_authorizations
   orderr = self.acme.new_order(csr_pem)
 File "/usr/lib/python3/dist-packages/acme/client.py", line 137, in new_order
   response = self._post(self.directory['newOrder'], order)
 File "/usr/lib/python3/dist-packages/acme/client.py", line 365, in _post
   return self.net.post(*args, **kwargs)
 File "/usr/lib/python3/dist-packages/acme/client.py", line 738, in post
   return self._post_once(*args, **kwargs)
 File "/usr/lib/python3/dist-packages/acme/client.py", line 751, in _post_once
   response = self._check_response(response, content_type=content_type)
 File "/usr/lib/python3/dist-packages/acme/client.py", line 602, in _check_response
   raise messages.Error.from_json(jobj)
acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MCwiaWF0IjoxNzYyMTEzMTgwLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.dtblj-pAQhtGrSJtHbNoJtLH-d51lwsP2fXsMCx420U
2025-11-02 19:53:00,766:ERROR:certbot._internal.log:An unexpected error occurred:
2025-11-02 19:53:00,766:ERROR:certbot._internal.log:Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MCwiaWF0IjoxNzYyMTEzMTgwLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.dtblj-pAQhtGrSJtHbNoJtLH-d51lwsP2fXsMCx420U
2025-11-02 19:53:01,852:DEBUG:certbot._internal.main:certbot version: 2.9.0
2025-11-02 19:53:01,852:DEBUG:certbot._internal.main:Location of certbot entry point: /bin/letsencrypt
2025-11-02 19:53:01,852:DEBUG:certbot._internal.main:Arguments: ['--manual', '-d', '121gamers.com', '-d', 'www.121gamers.com', '--preferred-challenges=dns', '--manual-auth-hook', '/etc/webmin/webmin/letsencrypt-dns.pl', '--manual-cleanup-hook', '/etc/webmin/webmin/letsencrypt-cleanup.pl', '--duplicate', '--force-renewal', '--non-interactive', '--agree-tos', '--config', '/tmp/.webmin/77695_3724969_5_letsencrypt.cgi', '--rsa-key-size', '2048', '--cert-name', '121gamers.com', '--no-autorenew', '--reuse-key', '--key-type', 'rsa']
2025-11-02 19:53:01,852:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2025-11-02 19:53:01,865:DEBUG:certbot._internal.log:Root logging level set at 30
2025-11-02 19:53:01,866:DEBUG:certbot._internal.plugins.selection:Requested authenticator manual and installer None
2025-11-02 19:53:01,867:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * manual
Description: Manual configuration or run your own shell scripts
Interfaces: Authenticator, Plugin
Entry point: EntryPoint(name='manual', value='certbot._internal.plugins.manual:Authenticator', group='certbot.plugins')
Initialized: <certbot._internal.plugins.manual.Authenticator object at 0x7a900bdedf10>
Prep: True
2025-11-02 19:53:01,867:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.manual.Authenticator object at 0x7a900bdedf10> and installer None
2025-11-02 19:53:01,867:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator manual, Installer None
2025-11-02 19:53:02,029:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/2583697836', new_authzr_uri=None, terms_of_service=None), a2d0a190a18033732ebc475838f79a8e, Meta(creation_dt=datetime.datetime(2025, 8, 9, 4, 26, 26, tzinfo=<UTC>), creation_host='paccione.co.uk', register_to_eff=None))>
2025-11-02 19:53:02,030:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2025-11-02 19:53:02,032:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2025-11-02 19:53:02,556:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 1065
2025-11-02 19:53:02,557:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 02 Nov 2025 19:53:02 GMT
Content-Type: application/json
Content-Length: 1065
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800
 "dWezubnRKLU": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
 "keyChange": "https://acme-v02.api.letsencrypt.org/acme/key-change",
 "meta": {
   "caaIdentities": [
     "letsencrypt.org"
   "profiles": {
     "classic": "https://letsencrypt.org/docs/profiles#classic",
     "shortlived": "https://letsencrypt.org/docs/profiles#shortlived (not yet generally available)",
     "tlsclient": "https://letsencrypt.org/docs/profiles#tlsclient",
     "tlsserver": "https://letsencrypt.org/docs/profiles#tlsserver"
   "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.5-February-24-2025.pdf",
   "website": "https://letsencrypt.org"
 "newAccount": "https://acme-v02.api.letsencrypt.org/acme/new-acct",
 "newNonce": "https://acme-v02.api.letsencrypt.org/acme/new-nonce",
 "newOrder": "https://acme-v02.api.letsencrypt.org/acme/new-order",
 "renewalInfo": "https://acme-v02.api.letsencrypt.org/acme/renewal-info",
 "revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert"
2025-11-02 19:53:02,557:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for 121gamers.com and www.121gamers.com
2025-11-02 19:53:03,692:DEBUG:acme.client:Requesting fresh nonce
2025-11-02 19:53:03,692:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2025-11-02 19:53:03,842:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2025-11-02 19:53:03,842:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 02 Nov 2025 19:53:03 GMT
Replay-Nonce: YicTj_5nfiisndfbIacQB8SzN17rPEJpsznbesMqOCVdscl23sI
2025-11-02 19:53:03,843:DEBUG:acme.client:Storing nonce: YicTj_5nfiisndfbIacQB8SzN17rPEJpsznbesMqOCVdscl23sI
2025-11-02 19:53:03,843:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "121gamers.com"\n    },\n    {\n      "type": "dns",\n      "value": "www.121gamers.com"\n    }\n  ]\n}'
2025-11-02 19:53:03,849:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
 "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjU4MzY5NzgzNiIsICJub25jZSI6ICJZaWNUal81bmZpaXNuZGZiSWFjUUI4U3pOMTdyUEVKcHN6bmJlc01xT0NWZHNjbDIzc0kiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
 "signature": "k3Us1zRlCB65cDJGUTrmbrFMgi9rCy7xRvggyMq1SLT0eS22ucbbxhCNvBK4434crfO4ue1bKnAtr2C8V6a95IEU-8m_hVmp5CXN1JMe_WKaJEG_yLzjZ0wp6U3BlK5IrUnM1cYEdExV_vE10tEs0t-H_DzGeLiji75YVwtAIbtpqEpT7X1b_bgw1aEhhzpi5gOyT9Yo6Yc-sEaDQ6cRGVcHIoPkmIoozav-fGyztYjMkzXFVu4yk0ETMsylmmwVak2APKdLs-qSA-WimRWKSw9OAXlZlJJtj_ubfomADybD88FWXA7SuP7AnEeXqb9nSqEj2-RIflDkVDO8z3DUdg",
 "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogIjEyMWdhbWVycy5jb20iCiAgICB9LAogICAgewogICAgICAidHlwZSI6ICJkbnMiLAogICAgICAidmFsdWUiOiAid3d3LjEyMWdhbWVycy5jb20iCiAgICB9CiAgXQp9"
2025-11-02 19:53:04,011:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 429 497
2025-11-02 19:53:04,011:DEBUG:acme.client:Received response:
HTTP 429
Server: nginx
Content-Length: 497
Replay-Nonce: YicTj_5nGaMWIvplBAXYifmhakvlEdyVAxxfgp8GMqSsALh9VwI
 "detail": "Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MywiaWF0IjoxNzYyMTEzMTgzLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.MuqVDjxCPxRUBeUcyo1MWPPprx8qxbwFc4h2rHVc7IM",
 "status": 429
2025-11-02 19:53:04,012:DEBUG:certbot._internal.log:Exiting abnormally:
acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MywiaWF0IjoxNzYyMTEzMTgzLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.MuqVDjxCPxRUBeUcyo1MWPPprx8qxbwFc4h2rHVc7IM
2025-11-02 19:53:04,015:ERROR:certbot._internal.log:An unexpected error occurred:
2025-11-02 19:53:04,015:ERROR:certbot._internal.log:Your account is temporarily prevented from requesting certificates for 121gamers.com and possibly others. Please visit: https://portal.letsencrypt.org/sfe/v1/unpause?jwt=eyJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJTRkUgVW5wYXVzZSIsImV4cCI6MTc2MzMyMjc4MywiaWF0IjoxNzYyMTEzMTgzLCJpZGVudGlmaWVycyI6IjEyMWdhbWVycy5jb20iLCJpc3MiOiJXRkUiLCJzdWIiOiIyNTgzNjk3ODM2IiwidmVyc2lvbiI6InYxIn0.MuqVDjxCPxRUBeUcyo1MWPPprx8qxbwFc4h2rHVc7IM
The error explains whats going on. Sound like you request too many times in a short period of time, you need to pause for a while then try again then show error if it happens.
