LetsEncrypt auto renew in Webmin
OS type and version EL10
Webmin version 2.641
Just noticed LE not auto renewing on Webmin only system.
Setting Months to renew to 2 then either Request Certificate or Just update renewal gets this:
Failed to request certificate : An ACME directory URL must be entered when using External Account Binding
Previous threads on this topic went unanswered.
I don’t have plain Webmin so I’m not sure if I see the same thing you do. Are you running a webserver? I seem to recall there was a code fix to allow for the cert even if not running one. Though if this is a renewal…
What options are you using, I would think last option would work fine.
Webmin only can use certbot standalone. And does, But the auto -renew is stuffed.
You can see the option “Certbot built-in server” It’s already selected as in Stefan’s post below yours.
If last option is the “Months between automatic renewal” - that is what causes the error message.
The " External Account Binding" puzzled me. I did a little research and the AI generated summary seemed to make sense. But, I scrolled down and found ‘the source’ as it were.
Don’t have time to read all that, I just reported an issue that I am having.
Will it get fixed? No idea.
Ok, I just noticed that you can’t select a SSL Provider, LetsEncrpyt is not mentions in the form unlike Virtualmin, @Jamie or @Ilia is this a bug?
Webmin
Virtualmin option
More like a missing feature - only Virtualmin supports multiple SSL providers, Webmin only supports Let’s Encrypt.
Right, OP error indicates the letsencrypt url directory is not being used automatically.
Yes, however, the latest versions of Webmin should include a way to configure any other ACME-compatible provider.
It’s not as simple or as flexible on a per-domain basis as Virtualmin Pro, but it still works.
I added this feature after a user requested it. See the advances “Provider settings” in the screenshot below:
Have you tested putting a number in “Months between automatic renewal”?
Ugh, gosh! You’re right—there was a bug. It’s really surprising how long it was there! Thanks for the tip! Fixed in this PR:
I am guessing that this bug will still be there until the next 6 monthly update?
This is the one that thing that really disappoints me about *min, you simply don’t bother to release updates for problems. I have no idea what the plan is except there is no plan.
Please move into this century.
I currently have a mail server off air because I can’t renew it’s LE certificate.
I also don’t know how to use Github, it doesn’t say anywhere that I have seen in the docs that learning Github is a pre-requisite for using *min.
We’re actually preparing a new Webmin 2.650 already.
Thanks to AI my server is at least back online now.
When have we ever gone six months between Webmin updates? I think we average about one release every two or three months, with occasional quick follow up releases for new bugs that made it through testing.
When setting the renewal period from Auto to eg 2 months, there should be a Save button as well as Request Certificate and Just Update Renewal?
Both options still fail:
Webmin version 2.651
I think I’m missing something. I updated to Webmin 2.651 because I saw your post about other ACME providers. I can’t find the Provider settings anywhere. I’m using Webmin 2.651 and Virtualmin GPL 8.1.0. Am I looking in the wrong place, or is this a Pro feature?
Thanks!
For Virtualmin integration, this is a Pro-only feature. However, now Webmin also lets you configure an ACME provider in a more general way using the “Provider settings” option in the “Webmin ⇾ Webmin Configuration: SSL Encryption” page.
