Hope you all are fine in these strange times…
I have an issue with renewing a Let’s Encrypt certificate, see the error below:
File “/usr/share/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/share/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 143, in get_crt
raise ValueError(“Wrote file to {0}, but couldn’t download {1}: {2}”.format(wellknown_path, wellknown_url, e))
ValueError: Wrote file to /home/web02/public_html/.well-known/acme-challenge/WQNPCps7R9vZz56341efp7MbevkuFsDkDQivGQej1gg, but couldn’t download http://web02.ossc.be/.well-known/acme-challenge/WQNPCps7R9vZz56341efp7MbevkuFsDkDQivGQej1gg: Error:
Url: http://web02.ossc.be/.well-known/acme-challenge/WQNPCps7R9vZz56341efp7MbevkuFsDkDQivGQej1gg
Data: None
Response Code: 404
Response:
Not Found
The requested URL /.well-known/acme-challenge/WQNPCps7R9vZz56341efp7MbevkuFsDkDQivGQej1gg was not found on this server.
usage: acme_tiny.py [-h] --account-key ACCOUNT_KEY --csr CSR --acme-dir
ACME_DIR [–quiet] [–disable-check]
[–directory-url DIRECTORY_URL] [–ca CA]
[–contact [CONTACT [CONTACT …]]]
acme_tiny.py: error: argument --acme-dir is required
After I created the .well-known/acme-challenge directory in the domain webhome the file was created.
The file can be opened via the web, so I’m not sure why Let’s Encrypt does not see it…
No redirects in .htaccess or vhost
Other domain on the same host renewed the certificate without an issue.
Operating system Ubuntu Linux 14.04.4
Webmin version 1.941
Virtualmin version 6.08
acme_tiny.py Jan 15 01:06 size: 11513
Any idea what I’m missing…?
Thanks in advance!
Kind regards
Johnny
