Let's Encrypt ssl not automatically renewed (re-issued)
OS type and version Debian 12.9
Webmin version 2.302
Virtualmin version 7.30.4 Pro
Webserver version Apache webserver 2.4.62
Related packages -
My Let’s Encrypt free certificates are not automatically renewing anymore for my virtual servers.
I have set to automatically renew once the certificate reaches 31 days to expire.
There’s nothing in /var/log/letsencrypt. No error just empty log file. How can I debug this? Is there a cronjob or log file i can check? It used to work fine for a couple of months but stopped working without notice or anything. I attached images of the settings i have currently set…
I also read various topics which are related to my issue but no dice.
If anyone has any advice thank you.
2
i’m failing to see the problem. system shows 31days today. so i would wait untill tomorrow and take another screenshot then, if it’s failing. there should be some error also in this screenshot if something has failed.
Ok I will wait one more day and keep this topic posted. Thank you for your reply.
It indeed renewed now :). The issue is resolved. Thanks.
