Let's Encrypt post-hook
Hi guys,
Is there any way to add “post-hook” action on SSL renewal? I looked everywhere and seems like there is no such option. The reason I’m asking is that I am using few custom services and I need them to be restarted to apply the new ssl certificates.
In my other setups I am using certbot --post-hook feature, but in Virtualmin there is no such option.
Is there an easy way to achieve this?
Kind regards,
Dean
Hello, Dean!
Yes, it is possible.
You should define a Command to run after making changes to a server in System Settings ⇾ Virtualmin Configuration / Actions upon server and user creation to point to a custom script, let’s say /usr/local/sbin/virtualmin-post-server.sh and there do something like this:
#!/bin/sh
if [ "$VIRTUALSERVER_ACTION" = "SSL_DOMAIN" ]; then
  # Update SSL certificates for Prosody
  /usr/bin/cp -f /home/$VIRTUALSERVER_DOM/ssl.key /etc/prosody/certs/$VIRTUALSERVER_DOM.key
  /usr/bin/cp -f /home/$VIRTUALSERVER_DOM/ssl.bundle /etc/prosody/certs/$VIRTUALSERVER_DOM.bundle
  /usr/bin/chmod 700 /etc/prosody/certs/$VIRTUALSERVER_DOM.bundle /etc/prosody/certs/$VIRTUALSERVER_DOM.key
  /usr/bin/chown prosody:prosody /etc/prosody/certs/$VIRTUALSERVER_DOM.key /etc/prosody/certs/$VIRTUALSERVER_DOM.bundle
  /usr/bin/systemctl restart prosody.service
  # Print all available env vars for a script
  /usr/bin/printenv > /root/virtualmin-all-envs
fi
Hello, Ilia!
Thank you for this, I already have seen this, but I thought this is only done when you create new users/domains/etc.
I will try this and update this ticket if needed.
