CentOS Linux 7.9.2009
Virtualmin version 6.15
When renewal fails due to backend rate-limit.
Must I pause virtualmin renewal requests to exit 5 day rate-limit imposed by Let’s Encrypt backend?
If yes how do I pause?
021-03-12 12:19:17,413:DEBUG:certbot._internal.log:Exiting abnormally:
File “/bin/letsencrypt”, line 9, in
load_entry_point(‘certbot==1.11.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 15, in main
return internal_main.main(cli_args)
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1421, in main
return config.func(config, plugins)
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1294, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File “/usr/lib/python2.7/site-packages/certbot/_internal/main.py”, line 124, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/usr/lib/python2.7/site-packages/certbot/_internal/renewal.py”, line 331, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
File “/usr/lib/python2.7/site-packages/certbot/_internal/client.py”, line 374, in obtain_certificate
orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names)
File “/usr/lib/python2.7/site-packages/certbot/_internal/client.py”, line 406, in _get_order_and_authorizations
orderr = self.acme.new_order(csr_pem)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 886, in new_order
return self.client.new_order(csr_pem)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 668, in new_order
response = self._post(self.directory[‘newOrder’], order)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 97, in _post
return self.net.post(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1201, in post
return self._post_once(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1214, in _post_once
response = self._check_response(response, content_type=content_type)
File “/usr/lib/python2.7/site-packages/acme/client.py”, line 1072, in _check_response
raise messages.Error.from_json(jobj)
Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: xxxxxxxx.com,www.xxxxxxxx.com: see Rate Limits - Let's Encrypt - Free SSL/TLS Certificates
2021-03-12 12:19:17,414:ERROR:certbot._internal.log:An unexpected error occurred:
2021-03-12 12:19:17,414:ERROR:certbot._internal.log:There were too many requests of a given type :: Error creating new order :: too many
