i try in two servers let’s encrypt failed in both of the servers is there a problem with let’s encrypt why both of the servers failed to take certificate
ok i will take a look at the error log of let’s encrypt if i cannot find a solution i will ask here for a help by posting also the log so if i understand what it tells i will ask help from you
i try one active domain and everything was fine with let’s encrypt so it’s obvious it it require an active domain to complete the process of let’s encrypt
