Let’s Encrypt
I reinstalled Virtualmin but I keep getting this error when trying to use Let’s Encrypt.
You appear to be attempting to generate a certificate for the domain arrowit.net. You must first check if the domain arrowit.net is resolving to the server on which Virtualmin runs.
When I attempt to visit the website of arrowit.net I get some cloudflare error. The website must work off the Virtualmin server before you can generate a Lets Encrypt certificate for it.
This is happening to all my domains even the ones not added to Cloudflare.
If you are seeing ‘…but couldn’t download url’ in the error log then you must first check if the domain is resolving to the server on which Virtualmin runs. The website must serve pages off the web server of the box on which Virtualmin runs before you can generate a Lets Encrypt certificate via Virtualmin.
If there is a redirect from http to https, then make sure to exclude the .well-known directory.
