Very recently in several virtualmin’s getting the same issue when generating SSL through backend.
certbot.errors.Error: Are you trying to change the key type of the certificate named *********** from ECDSA to RSA? Please provide both --cert-name and --key-type on the command line to confirm the change you are trying to make.
This prevents going forward and regenerate SSL successfully.
Already search at stackoverflow and Virtualmin Forum without luck.
Same issue here: the Let’s Encrypt renewal process crashes on one particular Virtual Server.
Plugins selected: Authenticator manual, Installer None
Attempting to parse the version 2.3.0 renewal configuration file found at /etc/letsencrypt/renewal/xxx.com.conf with version 1.12.0 of Certbot. This might not work.
Are you trying to change the key type of the certificate named xxx.com from ECDSA to RSA? Please provide both --cert-name and --key-type on the command line confirm the change you are trying to make.
For some reason, I see this in /etc/letsencrypt/renewal/xxx.com.conf:
version = 2.3.0
[renewalparams]
key_type = ecdsa
