Hello, there I have this problem my Virtualmin 6.03 and Webmin 1.930.
So every time auto-renewal must done, the certificate stops and give me an error
2020-08-27 21:03:11,040:INFO:certbot.renewal:Cert not yet due for renewal
2020-08-27 21:03:11,040:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/letsencrypt”, line 11, in
load_entry_point(‘certbot==0.31.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1365, in main
return config.func(config, plugins)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1243, in certonly
should_get_cert, lineage = _find_cert(config, domains, certname)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 286, in _find_cert
action, lineage = _find_lineage_for_domains_and_certname(config, domains, certname)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 323, in _find_lineage_for_domains_and_certname
return _handle_identical_cert_request(config, lineage)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 217, in _handle_identical_cert_request
default=0, force_interactive=True)
File “/usr/lib/python3/dist-packages/certbot/display/util.py”, line 155, in menu
code, selection = self._get_valid_int_ans(len(choices))
File “/usr/lib/python3/dist-packages/certbot/display/util.py”, line 418, in _get_valid_int_ans
ans = input_with_timeout(input_msg)
File “/usr/lib/python3/dist-packages/certbot/display/util.py”, line 85, in input_with_timeout
raise EOFError
EOFError
2020-08-27 21:03:11,041:ERROR:certbot.log:An unexpected error occurred:
every time I have to remove my domain files from /etc/letsencrypt/ files and then I have to renew it manually.
This been more than 3 months.
How can I fix that.
There have been several updates to the version of Virtualmin and Webmin that you are using and some of them relate to SSL / certbot. Would you like to update to the latest version and see if this fixes the issue?
Get cloud support with Ubuntu Advantage Cloud Guest: Pricing | Ubuntu
1 package can be updated.
0 updates are security updates.
New release ‘18.04.5 LTS’ available.
Run ‘do-release-upgrade’ to upgrade to it.
Last login: Thu Aug 27 21:02:31 2020 from 197.62.131.230
ubuntu@s1:~$ sudo cat /etc/apt/sources.list
## Note, this file is written by cloud-init on first boot of an instance
## modifications made here will not survive a re-bundle.
## if you wish to make changes you can:
## a.) add 'apt_preserve_sources_list: true' to /etc/cloud/cloud.cfg
## or do the same in user-data
## b.) add sources in /etc/apt/sources.list.d
## c.) make changes to template file /etc/cloud/templates/sources.list.tmpl
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://archive.ubuntu.com/ubuntu xenial main restricted
deb-src http://archive.ubuntu.com/ubuntu xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu xenial universe
deb-src http://archive.ubuntu.com/ubuntu xenial universe
deb http://archive.ubuntu.com/ubuntu xenial-updates universe
deb-src http://archive.ubuntu.com/ubuntu xenial-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://archive.ubuntu.com/ubuntu xenial multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial multiverse
deb http://archive.ubuntu.com/ubuntu xenial-updates multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
deb http://nginx.org/packages/mainline/ubuntu/ xenial nginx
deb-src http://nginx.org/packages/mainline/ubuntu/ xenial nginx
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
#deb [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable
# deb-src [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable
If thats the full source.list, then something got removed or broken.
It should contain the references to other files (which got the repo’s for virtualmin/etc) or it should be placed directly in the file.
I might be wrong here, but I think both are the same except one is triggered from cron or other timed services. Didn’t meant to be rude with my previous post, its just thats the information I found about it.
