| SYSTEM INFORMATION | |
| OS type and version | Debian Linux 12 |
| Webmin version | 2.610 |
| Virtualmin version | 7.50.2 GPL |
| Webserver version | Apache version 2.4.65 |
| Related packages | Cerbot 2.1.0 |
I have 12 vhosts controlled by virtualmin and I am trying to renew SSL certificates using Let’s encrypt with web-based authentication (virtualmin/my server does not control DNS).
- The 11 real domains/vhosts I made succeeds.
- The 1 out-of-the-box vhost for the virtualmin admin page fails though (It seems the docroot doesnt actually serve files)
working vhost without subdomains (only serverAlias)
cmd tried
sudo virtualmin generate-letsencrypt-cert --domain rueth.online --renew --web
=> no error, all succeeds
config
<VirtualHost *:80>
SuexecUserGroup #1006 #1006
ServerName rueth.online
ServerAlias www.rueth.online
ServerAlias mail.rueth.online
ServerAlias webmail.rueth.online
ServerAlias admin.rueth.online
DocumentRoot /home/ruethonline/public_html
ErrorLog /var/log/virtualmin/rueth.online_error_log
CustomLog /var/log/virtualmin/rueth.online_access_log combined
ScriptAlias /cgi-bin/ /home/ruethonline/cgi-bin/
ScriptAlias /awstats /home/ruethonline/cgi-bin/awstats.pl
DirectoryIndex index.php index.htm index.html
<Directory /home/ruethonline/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch
Require all granted
</Directory>
<Directory /home/ruethonline/cgi-bin>
Require all granted
</Directory>
ProxyPass /.well-known !
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.rueth.online
RewriteRule ^/(?!.well-known)(.*)$ https://rueth.online:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.rueth.online
RewriteRule ^/(?!.well-known)(.*)$ https://rueth.online:10000/ [R]
RemoveHandler .php
RemoveHandler .php8.2
RedirectMatch ^/awstats$ /awstats/
<FilesMatch \.php$>
SetHandler proxy:unix:/run/php/1759001099121642.sock|fcgi://127.0.0.1
</FilesMatch>
<Files awstats.pl>
AuthName "rueth.online statistics"
AuthType Basic
AuthUserFile /home/ruethonline/.awstats-htpasswd
require valid-user
</Files>
RewriteRule ^/(?!.well-known)(.*)$ https://%{HTTP_HOST}/$1 [R]
</VirtualHost>
<VirtualHost *:443>
Require all granted
</Directory>
Require all granted
</Directory>
RewriteEngine on
<FilesMatch \.php$>
</FilesMatch>
RemoveHandler .php
SSLEngine on
SSLCertificateFile /etc/ssl/virtualmin/1759001099121642/ssl.cert
SSLCertificateKeyFile /etc/ssl/virtualmin/1759001099121642/ssl.key
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
<Files awstats.pl>
AuthType Basic
require valid-user
</Files>
SSLCACertificateFile /etc/ssl/virtualmin/1759001099121642/ssl.ca
</VirtualHost>
testing also gets http 200
sudo mkdir -p /home/ruethonline/public_html/.well-known/acme-challenge/
echo OK | sudo tee /home/ruethonline/public_html/.well-known/acme-challenge/test
sudo namei -l /home/ruethonline/public_html/.well-known/acme-challenge/test
curl -Il http://rueth.online/.well-known/acme-challenge/test
bad vhost (virtualmin admin)
cmd tried
sudo virtualmin generate-letsencrypt-cert --domain ns3119878.ip-51-38-181.eu --renew --web
=> error from tool:
.. failed : Web-based validation failed : Saving debug log to /var/log/letsencrypt/letsencrypt.log
Renewing an existing certificate for ns3119878.ip-51-38-181.eu
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
Domain: ns3119878.ip-51-38-181.eu
Type: unauthorized
Detail: 51.38.181.35: Invalid response from http://ns3119878.ip-51-38-181.eu/.well-known/acme-challenge/3rvb1PTw0zBo2167LQ6-1HaygOP-11NCNNw_Fw5B8XY: 404
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
Some challenges have failed.
config
<VirtualHost *:80>
SuexecUserGroup #1001 #1001
ServerName ns3119878.ip-51-38-181.eu
DocumentRoot /home/._hostname/public_html
ErrorLog /var/log/virtualmin/ns3119878.ip-51-38-181.eu_error_log
CustomLog /var/log/virtualmin/ns3119878.ip-51-38-181.eu_access_log combined
ScriptAlias /cgi-bin/ /home/._hostname/cgi-bin/
<Directory /home/._hostname/public_html>
Require all granted
AddType text/plain .php
</Directory>
<Directory /home/._hostname/cgi-bin>
Require all granted
</Directory>
RemoveHandler .php
<FilesMatch \.php$>
SetHandler None
</FilesMatch>
</VirtualHost>
<VirtualHost *:443>
Require all granted
</Directory>
Require all granted
</Directory>
<FilesMatch \.php$>
SetHandler None
</FilesMatch>
RemoveHandler .php
SSLEngine on
SSLCertificateFile /etc/ssl/virtualmin/175897603948843/ssl.cert
SSLCertificateKeyFile /etc/ssl/virtualmin/175897603948843/ssl.key
SSLCACertificateFile /etc/ssl/virtualmin/175897603948843/ssl.ca
</VirtualHost>
testing also gets http 404
sudo mkdir -p /home/._hostname/public_html/.well-known/acme-challenge/
echo OK | sudo tee /home/._hostname/public_html/.well-known/acme-challenge/test
sudo namei -l /home/._hostname/public_html/.well-known/acme-challenge/
curl -Il http://ns3119878.ip-51-38-181.eu/.well-known/acme-challenge/test
