Joomla Auto-installer won't work with sample_data
Hi I have been trying to get the Joomla script to install under Virtualmin with my sample_data.sql. If you install Joomla manually you get a prompt to use this file. But with the auto script installer it’s not working. I even tried placing the files in the installation/sql/mysql folder, but I just cannot get it to work.
The reason I want the Virtualmin installer to control Joomla is because the interface works the same and when installed manually, things start acting funny.
Any help is appreciated.
Thank you,
-Dave
after installation, rename the configuration.php and browse to the website. you’ll see the installer again and then follow the steps.
I haven’t tried this, but seems a logic step to me
