Greetings, Everyone!
I am creating a website for my school and one last thing is missing : website send mail. I am running a beautiful server with the last Virtualmin (on Debian 8) with MySQL, and PHP 7. Everything is working fine : website and emails (both Roundcube and Thunderbird). Just PHPmail is not.
The webiste is running with Joomla 3.6 (support PHP 7) and when I run the test mail (Global Config > Mail Settings) after the proper mail values, the following error message appears: Notice: SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting and Error: Test mail could not be sent.
I also have a Mautic intance and when I run the test mail after the proper configuration, the error message appears: Connection to mydomain.tld:143 Timed Out Log data: ++ Starting Swift_SmtpTransport !! Connection to mydomain:143 Timed Out (code: 0) ++ Starting Swift_SmtpTransport !! Connection to espm.life:143 Timed Out (code: 0)
The reason why I think this is related with PHPMailer is because no evidence appears on /var/log/mail.*. The request of the message doesn’t get to Postfix. So I checked php.ini and I realized that sendmail_path = was commented and empty. So, I uncommented it and added first the default sendmail -t -i (as I figured in others topics on internet) then with postfix only. Restarted Apache in both situations and had no success.
I don’t know what I could do. So I am here to hear from you guys.
This is the /etc/postfix/master.cfg :
smtp inet n - - - - smtpd -o smtpd_sasl_auth_enable=yes
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
submission inet n - - - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
-o smtpd_reject_unlisted_recipient=no
-o smtpd_client_restrictions=$mua_client_restrictions
-o smtpd_helo_restrictions=$mua_helo_restrictions
-o smtpd_sender_restrictions=$mua_sender_restrictions
-o smtpd_recipient_restrictions=
-o smtpd_relay_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
smtps inet n - - - - smtpd
-o syslog_name=postfix/smtps
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup unix n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
submission inet n - - - - smtpd -o smtpd_sasl_auth_enable=yes
This is the php.ini:
[mail function]
sendmail_path = postfix
;mail.force_extra_parameters =
mail.add_x_header = On
mail.log =/home/mydomain/
This is tail /var/log/mail.log just after the request of test mail on website (nothing related) :
Jul 28 11:30:25 host1 postfix/anvil[1248]: statistics: max cache size 1 at Jul 28 08:27:04
Jul 28 11:56:15 host1 postfix/master[25292]: terminating on signal 15
Jul 28 11:56:35 host1 sendmail[4593]: alias database /etc/mail/aliases rebuilt by root
Jul 28 11:56:35 host1 sendmail[4593]: /etc/mail/aliases: 3 aliases, longest 4 bytes, 37 bytes total
Jul 28 11:56:36 host1 sm-mta[4641]: starting daemon (8.14.4): SMTP+queueing@00:10:00
Jul 28 12:22:26 host1 postfix/master[7231]: fatal: bind 0.0.0.0 port 25: Address already in use
Jul 28 12:23:21 host1 postfix/postfix-script[7280]: error: unknown command: ''
Jul 28 12:23:21 host1 postfix/postfix-script[7281]: fatal: usage: postfix start (or stop, reload, abort, flush, check, status, set-permissions, upgrade-configuration)
What should I do? Anyone?
Thanks in advance,
J.
