Im getting an error when I try and install perl modules… I can’t find any further information to help guide me to a fix… The error is below:
Executing /usr/bin/perl Makefile.PL && make …
Checking if your kit is complete…
Looks good
Writing Makefile for MIME::Base64
cp QuotedPrint.pm blib/lib/MIME/QuotedPrint.pm
cp Base64.pm blib/lib/MIME/Base64.pm
/usr/bin/perl /usr/share/perl5/vendor_perl/ExtUtils/xsubpp -typemap /usr/share/perl5/ExtUtils/typem
ap Base64.xs > Base64.xsc && mv Base64.xsc Base64.c
gcc -c -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/includ
e -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -DVE
RSION=“3.15” -DXS_VERSION=“3.15” -fPIC “-I/usr/lib64/perl5/CORE” Base64.c
/bin/sh: gcc: command not found
make: *** [Base64.o] Error 127
Installation of MIME::Base64 failed. Check the output above and try installing manually.
You can also install the module from CPAN with the command perl -MCPAN -e shell
