Iscsiadm: Connection to Discovery Address 192.168.1.xx failed
Webmin version 1.990
Cloudmin version 9.6 Pro
Unable to create VM.
  1. Host fails to connect to freshly installed iSCSI server also running CentOS7.9. 2009
  2. iSCSI server is added in Cloudmin and host is set to use its iSCSI storage.
  3. TCP port 3260 opened on new iSCSI server.
  4. The same host works flawlessly for an old iSCSI server.
  5. When attempting to manually connect from iSCSI client to iSCSI server IP address from Webmin, the following error appears:
Failed to add iSCSI connection : No iSCSI targets could be retrieved from 192.168.1.99 : iscsiadm: Connection to Discovery Address 192.168.1.99 failed
  • iSCSI client (host): CentOS7.9. 2009; Webmin 1.991; iSCSI client configured to start on boot
  • iSCSI TGTd (server): CentOS7.9. 2009; Webmin 1.991; iSCSI TGTd started, allows connections from all; Firewalld TCP Port 3260 open
What am I missing here?
I’ve been struggling with this too. Could not figure out why it doesn’t work :frowning:
Any update please? I’ve hit a wall here. Kinda stuck…
Did you get any further with this @surjo ?
I suspect the way in which a target iSCSI device is being created is out of date. RHEL 7 uses targetcli:
